7. Canny Edge Detection
In this chapter, we will capture real-time video using Raspberry Pi + Picamera2 and perform edge detection with OpenCV’s Canny algorithm. Edge detection is a fundamental part of computer vision, and the Canny algorithm is widely regarded as one of the most stable and noise-robust methods.
1. What Does the Canny Algorithm Do?
In images, edges usually correspond to locations with strong intensity (grayscale) changes, such as:
  • Object outlines
  • Boundaries between bright and dark regions
  • Structural edge lines
The purpose of Canny edge detection is to:
  • Accurately extract edge information while reducing unnecessary interference;
  • Provide a reliable foundation for subsequent contour detection, object segmentation, and geometric recognition (e.g., circles, rectangles);
  • In robot vision, it’s often used for path detection and obstacle recognition.
Illustration of Canny edge detection
2. Run the Code
Important
Before you start, make sure:
  • The pan-tilt is assembled
  • You can access the Raspberry Pi desktop
  • The code package is installed
  • Fusion HAT+ is installed and configured
  • OpenCV is installed
For detailed instructions, see 0. Setup OpenCV.
  1. Open the terminal and enter the following command:
    cd ~/ai-lab-kit/opencv_python
    python3 cv_7_canny.py
    Tip
    We also provide cv_7_canny_video.py to process video files, and cv_7_canny_conbine.py to combine real-time capture with video (combined view).
  2. When you run the program, two OpenCV windows will appear:
    • Camera – displays the live camera image
    • Canny Edges – displays the detected edges in real time
    You can adjust the edge detection thresholds using the trackbars. Press q or close any window to exit the program.
3. Complete Code
import cv2
# Empty callback function for trackbars (required by OpenCV API)
def _noop(x):
# Camera setup
picam2 = Picamera2()
# Create a preview configuration:
# size: resolution of the camera image
# format: XRGB8888 (4-channel image, similar to BGRA)
picam2.configure(
   picam2.create_preview_configuration(
      main={"size": (640, 480), "format": "XRGB8888"}
# Start the camera
picam2.start()
# Create OpenCV windows
WIN_CAM = "Camera"        # window for original image
WIN_EDGE = "Canny Edges"  # window for edge detection result
cv2.namedWindow(WIN_CAM)
cv2.namedWindow(WIN_EDGE)
# Create trackbars to tune Canny thresholds
# low_th: lower threshold for Canny
# high_th: higher threshold for Canny
cv2.createTrackbar("low_th",  WIN_EDGE, 50, 255, _noop)
cv2.createTrackbar("high_th", WIN_EDGE, 150, 255, _noop)
print("Press 'q' to exit")
# Main loop
   # Capture one frame from the camera (BGRA format)
   frame_bgra = picam2.capture_array()
   # Convert BGRA to BGR for OpenCV processing
   frame_bgr = cv2.cvtColor(frame_bgra, cv2.COLOR_BGRA2BGR)
   # Convert the frame to grayscale
   gray = cv2.cvtColor(frame_bgr, cv2.COLOR_BGR2GRAY)
   # Apply Gaussian blur to reduce noise
   blurred = cv2.GaussianBlur(gray, (5, 5), 0)
   # Read current threshold values from trackbars
   low_th = cv2.getTrackbarPos("low_th", WIN_EDGE)
   high_th = cv2.getTrackbarPos("high_th", WIN_EDGE)
   # Ensure high_th is always larger than low_th
   if high_th <= low_th:
      high_th = low_th + 1
      cv2.setTrackbarPos("high_th", WIN_EDGE, high_th)
   # Perform Canny edge detection
   edges = cv2.Canny(blurred, low_th, high_th)
   # Show original camera image
   cv2.imshow(WIN_CAM, frame_bgr)
   # Show edge detection result
   cv2.imshow(WIN_EDGE, edges)
   # Process GUI events and keyboard input
   key = cv2.waitKey(1) & 0xFF
   # Press 'q' to exit the program
   if key == ord("q"):
      break
   # Exit if the user closes any OpenCV window
   if (cv2.getWindowProperty(WIN_CAM, cv2.WND_PROP_VISIBLE) < 1 or
      cv2.getWindowProperty(WIN_EDGE, cv2.WND_PROP_VISIBLE) < 1):
      break
# Cleanup
picam2.stop()             # Stop the camera
cv2.destroyAllWindows()   # Close all OpenCV windows
4. Code Explanation
  1. Define a callback function for trackbars:
    def _noop(x):
    OpenCV trackbars require a callback function. We do not need to do anything inside it, so an empty function is enough.
  2. Initialize Picamera2 and set the preview format:
    picam2.configure(
    picam2.start()
    This starts the Raspberry Pi camera at 640×480. XRGB8888 is a 4-channel format, so frames are BGRA-like.
  3. Create two OpenCV windows:
    WIN_CAM = "Camera"
    One window shows the original camera image, and the other shows the Canny edge result.
  4. Create trackbars to adjust Canny thresholds in real time:
    • low_th: lower threshold for Canny.
    • high_th: higher threshold for Canny.
    You can drag these sliders to change the edge detection sensitivity.
  5. Capture a frame and convert it for OpenCV processing:
    The camera output is 4-channel, so we convert it to standard 3-channel BGR.
  6. Convert to grayscale and blur the image:
    • Canny works on grayscale images.
    • Gaussian blur reduces noise, which helps avoid detecting too many false edges.
  7. Read trackbar values and keep them valid:
    Canny expects high_th to be larger than low_th. This block automatically fixes the values if the user drags them too close.
  8. Run Canny edge detection:
    Canny highlights strong edges in the image. Lower thresholds usually detect more edges, but also more noise.
  9. Display both windows:
    The left window shows the live camera feed, and the other shows the detected edges.
  10. Exit conditions (press q or close the window):
    if key == ord("q"):
        break
        break
    This allows beginners to stop the program in two ways: keyboard or closing the window.
  11. Cleanup:
    picam2.stop()
    Always stop the camera and close all OpenCV windows to release resources.
5. Why is Canny Useful?
Canny output is well-suited for subsequent vision tasks:
Application
Contour detection
Use cv2.findContours on Canny output to obtain object shapes
Object segmentation
Use edges as a basis to separate target from background
Shape recognition
Combine with Hough transforms to detect circles, lines, etc.
Robot navigation
Detect ground, roads, obstacle outlines to assist planning
OCR / Target localization
Text regions, QR codes, markers often have clear edge features
Canny isn’t just “cool-looking”—it’s the entry point to a broader CV pipeline.
6. Threshold Selection Tips
Scenario
low_th
high_th
Notes
Stable indoor lighting
50
150
General case, stable results
Strong lighting & high contrast
100
200
Increase thresholds to reduce false edges
Low light, noisy
30
100
Lower thresholds to keep more details
Very blurry edges
20
80
Lower thresholds further to make edges more sensitive
Use the trackbars to quickly tune an appropriate range, then hardcode it into your program.
7. Extended Exercises
  • Use cv2.findContours on the Canny output to draw object boundaries.
  • Change the Gaussian kernel size and observe how edge accuracy changes.
  • Try different thresholds in low/high light to understand double-threshold effects.
  • Use the edge map for shape detection with cv2.HoughLines (lines) or cv2.HoughCircles (circles).
