6. CAMShift Object Tracking
In the previous chapter, we learned the MeanShift algorithm, which can continuously track a target in a video based on its color histogram. In this section, we introduce CAMShift (Continuously Adaptive Mean Shift), which extends MeanShift by automatically adapting the window size and orientation, making it more practical for real-world applications. Additionally, in this example we’ll track a target based on brightness rather than color, which is also very common in practice.
1. Algorithm Features
MeanShift can only track target position and uses a fixed-size window. CAMShift tracks position and automatically adjusts window size and angle.
For example, when the target approaches the camera, the tracking box grows; when the target moves away, it shrinks; when the target rotates, the box rotates accordingly.
CAMShift tracking illustration
2. Run the Code
Important
Before you start, make sure:
  • The pan-tilt is assembled
  • You can access the Raspberry Pi desktop
  • The code package is installed
  • Fusion HAT+ is installed and configured
  • OpenCV is installed
For detailed instructions, see 0. Setup OpenCV.
  1. Open the terminal and enter the following command:
    cd ~/ai-lab-kit/opencv_python
    python3 cv_6_camshift.py
  2. When you run the program, an OpenCV window named CAMShift Tracker will appear and start playing the video file sample3.mp4.
    The program tracks the black cat using the CAMShift (Continuously Adaptive Mean Shift) algorithm.
    A green rotated bounding box will be drawn around the tracked object. As the cat moves or changes its size and orientation, the tracking window will automatically adapt its position, size, and angle.
    You can exit the program in two ways:
    • Press the q key on the keyboard
    • Close the window by clicking the close button (X)
    After exiting, the video playback stops and all OpenCV windows are closed.
3. Complete Code
Open cv_6_camshift.py to view the full code.
# Python program to demonstrate CAMShift (tracking a dark object)
import numpy as np
import cv2
# Read video
cap = cv2.VideoCapture("sample3.mp4")
# Retrieve the first frame from the video
ret, frame = cap.read()
if not ret:
   raise RuntimeError("Cannot read the video file.")
# Set the initial region for tracking window (x, y, width, height)
x, y, w, h = 100, 200, 40, 40
track_window = (x, y, w, h)
# Convert first frame to HSV
hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
# Extract ROI (only the target area) in HSV
hsv_roi = hsv[y:y+h, x:x+w]
# For tracking a black object, we keep dark pixels (low V) inside ROI
# V channel is hsv[..., 2], so we build a mask based on V <= 80
roi_mask = cv2.inRange(hsv_roi, np.array((0, 0, 0)), np.array((180, 255, 80)))
# Build histogram on V channel (channel index 2) within ROI
# Use 256 bins for V (0~256) to match back projection range
roi_hist = cv2.calcHist([hsv_roi], [2], roi_mask, [256], [0, 256])
cv2.normalize(roi_hist, roi_hist, 0, 255, cv2.NORM_MINMAX)
# Termination criteria for CAMShift
term_crit = (cv2.TERM_CRITERIA_EPS | cv2.TERM_CRITERIA_COUNT, 10, 1)
# FPS delay (fallback if FPS is unavailable)
fps = cap.get(cv2.CAP_PROP_FPS)
if not fps or fps <= 1e-3:
   fps = 30.0
delay_ms = int(1000 / fps)
WINDOW_NAME = "CAMShift Tracker"
   # If video ends, restart from beginning
   if not ret:
      cap.set(cv2.CAP_PROP_POS_FRAMES, 0)
      continue
   # Convert frame to HSV
   # Back projection on V channel using ROI histogram (range 0~256)
   back_proj = cv2.calcBackProject([hsv], [2], roi_hist, [0, 256], 1)
   # Apply CAMShift
   rot_rect, track_window = cv2.CamShift(back_proj, track_window, term_crit)
   # Draw rotated rectangle
   pts = cv2.boxPoints(rot_rect).astype(np.int32)
   cv2.polylines(frame, [pts], True, (0, 255, 0), 2)
   cv2.putText(frame, "CAMShift Tracker", (10, 30),
               cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2)
   cv2.imshow(WINDOW_NAME, frame)
   # Keyboard + GUI events
   key = cv2.waitKey(delay_ms) & 0xFF
   if key == ord("q"):
      break
   # Exit if user closes the window (click X)
   if cv2.getWindowProperty(WINDOW_NAME, cv2.WND_PROP_VISIBLE) < 1:
      break
cap.release()
cv2.destroyAllWindows()
4. Code Explanation
  1. Open the video file and read the first frame:
    if not ret:
    CAMShift needs an initial frame to learn what to track.
  2. Set the initial tracking window (ROI):
    This rectangle should cover the target object in the first frame. CAMShift will update this window automatically during tracking.
  3. Convert the first frame to HSV and extract the ROI:
    HSV is convenient for tracking because you can choose specific channels (like V for brightness).
  4. Build a mask for a dark object (low V values):
    This keeps only “dark” pixels in the ROI. For black/dark objects, brightness (V) is usually the most useful feature.
  5. Compute and normalize a histogram of the V channel:
    • Channel 2 means the V (Value/brightness) channel in HSV.
    • The histogram describes how “dark/bright” the target ROI is.
    • Normalization makes tracking more stable.
  6. Set the termination criteria for CAMShift:
    CAMShift stops updating when it reaches 10 iterations or the movement is smaller than 1 pixel.
  7. Set playback speed using FPS:
        fps = 30.0
    This sets a delay so the video plays close to its original FPS.
  8. Create a probability map using back projection (V channel):
    Back projection highlights pixels in the frame whose V values match the ROI histogram. Brighter values in back_proj mean “more likely to be the target”.
  9. Track using CAMShift and update the window:
    CAMShift is based on MeanShift, but it can also adapt the size and rotation of the tracking window.
    • track_window is updated each frame.
    • rot_rect contains a rotated rectangle (center, size, angle).
  10. Draw the rotated tracking box:
    This converts the rotated rectangle into four corner points and draws it on the frame.
  11. Exit conditions (keyboard + window close):
    if key == ord("q"):
        break
        break
    Press q to quit, or close the window to stop safely.
  12. Release resources:
    cap.release()
    Always release the video file and close windows at the end.
5. CAMShift vs. MeanShift
Feature
MeanShift
CAMShift
Window size
Fixed
Adaptive
Angle
Not supported
Supports rotation
Tracking accuracy
Moderate
Higher, more adaptive
Applications
Static targets
Complex motion, rotating targets
CAMShift is an upgrade over MeanShift, better handling target deformation, rotation, and distance changes—well-suited for real-world scenarios.
6. Extensions and Practice
  • Adjust the inRange thresholds to track green or blue targets
  • Combine with live camera input to build a real-time color-based tracking system
7. Advanced: Interactive ROI Selection and Auto-Adjusting HSV Thresholds
As in the previous section, this project can also use mouse interaction to select the ROI and automatically adjust HSV thresholds.
Run cv_6_camshift_auto.py for the modified code.
python3 cv_6_camshift_auto.py
When you run the program, the first frame of the video will be displayed, and you will be asked to select a Region of Interest (ROI) with the mouse.
Drag the mouse to draw a rectangle around the target object, then press Enter or Space to confirm the selection. Press Esc to cancel the selection.
After selecting the ROI, a window named CAMShift Tracker will appear. The selected object will be tracked with a green rotated rectangle, and the tracking window will automatically adapt its position, size, and orientation as the object moves.
To stop the program:
  • Or close the display window using the close button (X)
hsv0 = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
roi_hsv = hsv0[y:y + h, x:x + w]
# Split ROI HSV channels
h_roi = roi_hsv[:, :, 0]
s_roi = roi_hsv[:, :, 1]
v_roi = roi_hsv[:, :, 2]
# Use percentiles to get robust ranges (ignore outliers)
h_low, h_high = np.percentile(h_roi, [5, 95])
s_low, s_high = np.percentile(s_roi, [5, 95])
v_low, v_high = np.percentile(v_roi, [5, 95])
# Add padding so the range is not too tight
pad_h, pad_s, pad_v = 10, 20, 20
lower = np.array([
   max(int(h_low) - pad_h, 0),
   max(int(s_low) - pad_s, 0),
   max(int(v_low) - pad_v, 0)
], dtype=np.uint8)
upper = np.array([
   min(int(h_high) + pad_h, 180),
   min(int(s_high) + pad_s, 255),
   min(int(v_high) + pad_v, 255)
], dtype=np.uint8)
# Mask ONLY the ROI (do not use the whole frame mask)
roi_mask = cv2.inRange(roi_hsv, lower, upper)
