2. Play Video
In this chapter, you’ll learn how to read and play video streams in OpenCV, and how to control playback speed by calculating the frame processing time.
1. Project Overview
In this section, we will achieve the following goals:
  • Use cv2.VideoCapture to open a video file
  • Read and display video frame by frame
  • Automatically restart the video after it ends
  • Control the playback frame rate using processing time calculations
  • Press the q key to exit playback
Video playback interface illustration
2. Run the Code
Important
Before you start, make sure:
  • The pan-tilt is assembled
  • You can access the Raspberry Pi desktop
  • The code package is installed
  • Fusion HAT+ is installed and configured
  • OpenCV is installed
For detailed instructions, see 0. Setup OpenCV.
  1. Open the terminal and enter the following command:
    cd ~/ai-lab-kit/opencv_python
    python3 cv_2_video.py
  2. After running the script, OpenCV opens a window titled Video and displays the video frames in real time.
    If the video reaches the end, it will restart automatically from the beginning.
    To stop the program, you can:
    • Press q on the keyboard to quit playback
    • Close the window by clicking the close button
    Once the window is closed, all OpenCV resources are released and the program exits.
3. Complete Code
import cv2
# Open the video file
cap = cv2.VideoCapture("sample2.mp4")
    # Read one frame from the video
    ret, frame = cap.read()
    # If the video ends, restart from the beginning
    if not ret:
        cap.set(cv2.CAP_PROP_POS_FRAMES, 0)
        continue
    # Resize the frame for better display performance
    frame = cv2.resize(frame, (640, 480))
    # Display the frame in a window named "Video"
    cv2.imshow("Video", frame)
    # Wait 30 ms between frames (~30 FPS)
    # This also processes GUI events (keyboard and window events)
    key = cv2.waitKey(30) & 0xFF
    # Press 'q' to exit the program
    if key == ord("q"):
        break
    # Exit if the user closes the window (click the close button)
    if cv2.getWindowProperty("Video", cv2.WND_PROP_VISIBLE) < 1:
        break
# Release the video capture object
cap.release()
# Close all OpenCV windows
cv2.destroyAllWindows()
4. Code Explanation
  1. Open the video file:
    This opens the video file and creates a VideoCapture object for reading frames.
  2. Read one frame from the video:
    • ret is True if a frame is read successfully.
    • ret becomes False when the video ends or reading fails.
    • frame is the image data (a NumPy array).
  3. Loop the video when it ends:
    if not ret:
        continue
    When the video ends, this resets the playback position to the first frame so the video can restart.
  4. Resize the frame:
    This resizes each frame to 640×480 for smoother display and lower CPU usage on Raspberry Pi.
  5. Display the frame:
    This displays the current frame in a window named Video.
  6. Control playback speed and read keyboard input:
    This waits about 30 ms between frames (around 30 FPS) and processes GUI events.
  7. Exit by pressing q:
    if key == ord("q"):
        break
    Press q to stop the program.
  8. Exit when the window is closed:
        break
    This checks whether the window is still visible. If the user closes the window, the program exits safely.
  9. Release the video capture object:
    cap.release()
    This releases the video file resource.
  10. Close all OpenCV windows:
    This closes all OpenCV windows and releases GUI resources.
5. Further Practice
  • Try changing the window size to see how it affects image clarity.
  • Replace the video file with different ones to test compatibility.
  • Print the processing time per frame to better understand the relationship between FPS and playback delay.
