5.12 Serial Read¶
You may have noticed this when using the Serial.print() function.
Since there is printing, is there reading? What is the text box on the Serial Monitor used for?
Yes, you guessed it, there are ways to control programs and circuits by entering information through the text box on the Serial Monitor.
In this project, we will use the I2C LCD1602 to display the text entered in the Serial Monitor in order to experience the usage of Serial.read().
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
Open the
5.12.serial_read.inofile under the path of3in1-kit\basic_project\5.12.serial_read.Or copy this code into Arduino IDE.
The
LiquidCrystal I2Clibrary is used here, you can install it from the Library Manager.
After the code is uploaded successfully, you can enter text in the text box on the serial monitor, and the LCD will display the information.
How it works?
void loop() { // when characters arrive over the serial port... if (Serial.available()) { // wait a bit for the entire message to arrive delay(100); // clear the screen lcd.clear(); // read all the available characters while (Serial.available() > 0) { // display each character to the LCD lcd.write(Serial.read()); } } }
Serial.available()can get the number of characters available in the incoming stream when you type something from the textbox. Since there are two terminators in the input, you actually have 3 characters when you typeA, and 4 characters when you typeAB.Serial.read()will take the first character from the incoming stream. For example, if you typedAB, callingSerial.read()only once, will get the characterA; The second call, you will getB; the third and fourth call, you will get two end symbols; calling this function when the input stream has no characters available will result in an error.
To sum up, it is common to combine the above two, using a while loop to read all characters entered each time.
while (Serial.available() > 0) { Serial.print(Serial.read()); }
By the way, if you don’t use Serial.read() to get characters from the incoming stream, the characters from the incoming stream will be stacked together.
For example, if you type A followed by AB, the incoming stream will accumulate 7 characters.
