3. Install the Driver on Different Systems
This section provides instructions for installing the 3.5’’ IPS screen driver on different operating systems. Please select the guide that matches the system installed on your Raspberry Pi.
Currently, the 3.5-inch display is only compatible with Raspberry Pi 4 and Raspberry Pi 5. For Raspberry Pi 3B, 3B+, and Zero 2W, it is not recommended to use them with the 3.5-inch display, as installing the touchscreen driver may cause it to malfunction.
