.. include:: /index.rst :start-after: start_hello_message :end-before: end_hello_message .. _install_driver: 3. Install the Driver on Different Systems ============================================= This section provides instructions for installing the 3.5'' IPS screen driver on different operating systems. Please select the guide that matches the system installed on your Raspberry Pi. .. note:: Currently, the 3.5-inch display is only compatible with Raspberry Pi 4 and Raspberry Pi 5. For Raspberry Pi 3B, 3B+, and Zero 2W, it is not recommended to use them with the 3.5-inch display, as installing the touchscreen driver may cause it to malfunction. .. toctree:: :maxdepth: 1 install_driver_rpios install_driver_ubuntu install_driver_kali install_driver_retropie
