Hardware Description
Parameters
Parameter
Screen Size
3.5-inch
LCD Type
IPS
Viewing Angle
Full Viewing Angle
Module Interface
SPI (Supports up to 125MHz SPI input)
Resolution
320×480 (Pixel)
Number of Pins
40-pin (Same as the Raspberry Pi)
Colors
65K
Touch Screen Controller
XPT2046
LCD Driver IC
ST7796U
Backlight
LED
Power Consumption
0.16A × 5V
Working Temperature (℃)
-20 ~ 60
Active Area
48.96 × 73.44 (mm)
Module PCB Size
85.42 × 55.60 (mm)
Package Size
132 × 96 × 40 (mm)
Product Weight (Including Package)
93.8 g
Interface Definition
Here is the pinout diagram for the 3.5-inch IPS screen. In reality, only the first 26 pins are connected. Pins 27–40 are not connected; they are only there to be compatible with the current 40-pin Raspberry Pi models and to reduce the chance of incorrect insertion.
_images/3.5_ips_pins.png
PIN NO.
SYMBOL
DESCRIPTION
1, 17
3.3V
Power supply input (3.3V)
2, 4
5V
Power supply input (5V)
3, 5, 7, 8, 10, 12, 13, 15, 16, 27~40
NC
Not connected
6, 9, 14, 20, 25
GND
Power ground
11
TP_IRQ
Touch panel interrupt signal, active low when pressed
18
LCD_RS
LCD register select signal (low: instruction, high: data)
19
LCD_SI / TP_SI
SPI data input for LCD display / touch panel
21
TP_SO
SPI data output from the touch panel
22
RST
Reset signal, active low
23
LCD_SCK / TP_SCK
SPI clock signal for LCD display / touch panel
24
LCD_CS
LCD chip select signal, active low
26
TP_CS
Touch panel chip select signal, active low
Fan Pins
On the back of the screen, there are two fan pins that allow you to connect an external fan. However, once the fan is connected, it will run continuously and cannot be controlled by code.
_images/3.5_ips_fan_pins.png
