πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1. What Else Do You Need?
Before we start using this screen, let’s prepare the essential hardware.
Required Components
  • Raspberry Pi
    • Compatible models: Raspberry Pi 5, Raspberry Pi 4 Model B
    • Other Raspberry Pi models are not supported.
    ../_images/need_pi.jpg
  • Power Adapter
    Different Raspberry Pi models require different power supplies. For best stability, it is recommended to use the official power adapter:
    • Raspberry Pi 5: Recommended: 5V 5A USB-C power supply (Official 27W PSU). You may also use a USB-C Power Delivery (PD) charger, as long as it provides sufficient current.
    • Raspberry Pi 4 Model B: Recommended: 5V 3A USB-C power supply (Official 15W PSU). You may also use a USB-C PD or QC 2.0 fast charger.
    ../_images/need_power.png
  • Micro SD Card
    The Raspberry Pi does not include built-in storage. It boots and stores all data on a Micro SD card.
    ../_images/need_sd.jpg
    • Minimum: 16GB
    • Recommended: 32GB or higher for better performance and stability
    • Recommended brands: SanDisk, Samsung
Optional Components
Although not strictly required, the following peripherals will significantly improve your setup and debugging experience:
  • Monitor (HDMI or TV)
    For beginners, we strongly recommend using a display with an HDMI input. This makes it easier to configure the system and run graphical programs.
    ../_images/need_screen.png
  • Micro HDMI Cable
    • The Raspberry Pi 4B and Raspberry Pi 5 require a Micro HDMI cable to connect to a display.
    • It is recommended to use the HDMI0 port (the one closest to the USB-C power port).
    ../_images/need_hdmi.png
  • Keyboard & Mouse
    • These are very useful during the initial OS setup.
    • You can switch to remote access (SSH/VNC) later, but for beginners, a basic USB or wireless keyboard and mouse are highly recommended.
    ../_images/need_keyboard_mouse.png
