Install 3.5’’ IPS Screen Driver on Kali
This section guides you through installing the 3.5’’ IPS screen driver on Kali Linux. You will log in to the system, open a terminal, and install the driver to enable display output on the 3.5’’ IPS screen.
Install 3.5’’ IPS Screen Driver (Important)
  1. Connect your Raspberry Pi to a monitor and power it on. Make sure an Ethernet cable is connected for network access.
    ../_images/connect_all_kali.jpg
  2. Log in using the default Kali credentials:
    • Username: kali
    • Password: kali
    After logging in, search for and open the Terminal.
  3. Open the built-in Firefox browser and visit:
    35-ips-screen.rtfd.io
  4. Copy and run the following commands in the Terminal one by one to install the driver:
    sudo rm -rf LCD-show-kali
    git clone https://github.com/sunfounder/LCD-show-kali.git
    chmod -R 755 LCD-show-kali
    cd LCD-show-kali/
    sudo ./MHS35IPS-show
  5. After the installation is complete:
    • Disconnect the HDMI monitor.
    • The Raspberry Pi will reboot automatically.
    • After rebooting, the system will be displayed on the 3.5’’ IPS screen.
Rotate the Display
You can change the screen and touch orientation by running:
cd LCD-show-kali/
sudo ./rotate.sh 90
The system will reboot automatically. After restart, the display and touch direction will be rotated to 90°. You can replace 90 with 0, 180, or 270 to set your desired orientation.
