TT Motor
This is a TT DC motor with a gear ratio of 1:48, it comes with 2 x 250mm wires with XH2.54-2P connector.
You can power these motors with 3 ~ 6VDC, but of course, they will go a little faster at higher voltages.
Note that these are very basic motors with no built-in encoder, speed control or position feedback. The voltage goes in and the spin comes out. There will be variation from motor to motor, so if you need precise motion, you’ll need a separate feedback system.
Features
Rated Voltage: 3~6V
Continuous No-Load Current: 150mA +/- 10%
Min. Operating Speed (3V): 90+/- 10% RPM
Min. Operating Speed (6V): 200+/- 10% RPM
Stall Torque (3V): 0.4kg.cm
Stall Torque (6V): 0.8kg.cm
Gear Ratio: 1:48
Body Dimensions: 70 x 22.3 x 36.9mm
Wires: Gray and Black, 24AWG, 250mm
Connector: XH2.54-2P
Weight: 30.6g
Dimensional Drawing
Unit: mm
