4 RGB LEDs Strip
+5V: Common anode of the three LEDs and needs to connect to DC 5V
B: Cathode of the blue LED
R: Cathode of the red LED
G: Cathode of the green LED
The RGB strip is composed of 4 RGB LEDs and has the ability to produce any shade of any color, it is a mixture of three primary colors; red, blue and green.
The RGB LEDs used are 5050, connected in a common anode way. Each LED is an independent circuit, can be cut along the switch at will, without damaging other parts. Made of FPC board, backed with double-sided adhesive, can be bent and secured at will.
Features
Work Voltage: DC5V
Color: Full color RGB
Working Temperature: -15-50
RGB Type: 5050RGB
Current: 150mA (single circuit)
Power: 1.5W
Light Strip Thickness: 2mm
Light Strip Width: 5.5mm
Cable: ZH1.5-4P, 25cm, 28AWG, Black
