8. Move Field Centric
This project is based on the previous project to combine the compass function to the movement of Zeus Car. While you control the Zeus Car movement with the remote control, if it is deflected by an external force (e.g. kicked by a dog), it will automatically deflect back to the original direction.
How to do?
The ESP32-CAM and the Arduino board share the same RX (receive) and TX (transmit) pins. So, when you’re uploading code, you’ll need to first disconnect the ESP32-CAM to avoid any conflicts or potential issues.
Open the
8_move_field_centric.inofile under the path ofzeus-car-main\examples\8_move_field_centric.After the code is uploaded successfully, slide the power switch to ON to start the Zeus Car.
Then use the number 1 ~ 9 on the remote control to control the car in 8 directions. After pressing a key, the Zeus Car will keep moving until you press
or the number key 5.When you press
once, the car will rotate counterclockwise with the body as the center and will stop until you press
or the number key 5.Similarly, pressing
once will make the car rotate clockwise, and then it will stop until you press
or the number key 5.Press the
key, the car will drift to the left.Press the
key, the car will drift to the right.
