Lesson 3 Flowing LED Lights¶
Introduction¶
In this lesson, we will learn how to make eight LEDs blink in various effects as you want based on Raspberry Pi.
Schematic Diagram¶
Set GPIO17-GPIO25 to low level in turn by programming, and then LED0-LED7 will light up in turn. You can make eight LEDs blink in different effects by controlling their delay time and the order of lighting up.
Experimental Procedures¶
Step 1: Build the circuit.
Step 2: GPIO4 is the default pin for onewire driver (w1-gpio). In this lesson, we need to disable the onewire function and use it as an output pin.
sudo nano /boot/config.txt
Commit the following line.
#dtoverlay = w1-gpio
For C Language Users:¶
Step 3: Change directory.
cd /home/pi/Sunfounder_SuperKit_C_code_for_RaspberryPi/03_8Led/
Step 4: Compile.
gcc 8Led.c -o 8Led -lwiringPi
Step 5: Run.
sudo ./8Led
If it does not work after running, or there is an error prompt: “wiringPi.h: No such file or directory”, please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
//make led_n on
void led_on(int n)
digitalWrite(n, LOW);
//make led_n off
void led_off(int n)
digitalWrite(n, HIGH);
int main(void)
int i;
for(i=0;i<8;i++){
printf("linker LedPin : GPIO %d(wiringPi pin)\n",i); //when initialize wiring successfully,print message to screen
for(i=0;i<8;i++){ //make 8 pins' mode is output
pinMode(i, OUTPUT);
for(i=0;i<8;i++){ //make led on from left to right
led_on(i);
delay(100);
led_off(i);
// delay(500);
for(i=8;i>=0;i--){ //make led off from right to left
led_on(i);
delay(100);
led_off(i);
For Python Users:¶
cd /home/pi/Sunfounder_SuperKit_Python_code_for_RaspberryPi/
Step 4: Run.
sudo python3 03_8Led.py
Then you will see eight LEDs brighten and dim left to right and right to left circularly, just like flowing water.
import RPi.GPIO as GPIO
pins = [17, 18, 27, 22, 23, 24, 25, 4]
def setup():
GPIO.setmode(GPIO.BCM) # Numbers GPIOs by BCM
for pin in pins:
GPIO.setup(pin, GPIO.OUT) # Set all pins' mode is output
GPIO.output(pin, GPIO.HIGH) # Set all pins to high(+3.3V) to off led
def loop():
for pin in pins:
GPIO.output(pin, GPIO.LOW)
time.sleep(0.05)
for pin in reversed(pins):
time.sleep(0.05)
def destroy():
for pin in pins:
GPIO.output(pin, GPIO.HIGH) # turn off all leds
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Further Exploration
You can write the blinking effects of LEDs in an array. If you want to use one of these effects, you can call it in the main() function directly.
