RGB Module
  • βœ… Be the first to get free learning resources.
  • βœ… Stay updated on new products & exclusive giveaways.
  • βœ… Share your creations and get real feedback.
  • πŸ‘‰ Need faster updates or support? Click [here] join our Facebook community
  • πŸ‘‰ Or join our WhatsApp group: Click [here]
Kit purchase
Looking for parts? Check out our all-in-one kits below β€” packed with components, beginner-friendly guides, and tons of fun.
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, we will learn how to use the RGB LED Module with Arduino.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
RGB LED Module
../_images/09_RGB_Module_bb.png
Common Connections:
  • RGB LED Module
    • R: Connect to 11 on the Arduino.
    • G: Connect to 10 on the Arduino.
    • B: Connect to 9 on the Arduino.
    • -: Connect to GND on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
  This code initializes an RGB LED module and displays the primary colors of red, green, and blue.
  It then proceeds to display the seven colors of the rainbow in sequence.
  Board: Arduino Uno R3 (or R4)
  Component: RGB LED module
// Pin numbers for each color channel
const int rledPin = 11;  // pin connected to the red color channel
const int gledPin = 10;  // pin connected to the green color channel
const int bledPin = 9;   // pin connected to the blue color channel
  pinMode(rledPin, OUTPUT);
  pinMode(gledPin, OUTPUT);
  pinMode(bledPin, OUTPUT);
setColor(255, 0, 0);  // Set RGB LED color to red
delay(1000);
setColor(0, 255, 0);  // Set RGB LED color to green
delay(1000);
setColor(0, 0, 255);  // Set RGB LED color to blue
delay(1000);
// Display the colors of the rainbow
delay(1000);
setColor(255, 165, 0);  // Set RGB LED color to orange
delay(1000);
setColor(255, 255, 0);  // Set RGB LED color to yellow
delay(1000);
setColor(0, 128, 0);  // Set RGB LED color to green
delay(1000);
delay(1000);
setColor(75, 0, 130);  // Set RGB LED color to indigo
delay(1000);
setColor(230, 130, 238);  // Set RGB LED color to violet
delay(1000);
void setColor(int R, int G, int B) {
  // Set the intensity of the red color channel
  analogWrite(rledPin, R);
  // Set the intensity of the green color channel
  analogWrite(gledPin, G);
  // Set the intensity of the blue color channel
  analogWrite(bledPin, B);
