Heart Rate Sensor Module
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, we will learn how to use the Heart Rate Sensor Module with Arduino.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
../_images/14_MAX30102_Module_bb.png
Common Connections:
  • Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
    • VIN: Connect to breadboard’s red power bus.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for MAX30105 and heartRate and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
  This is a demo to show the reading of heart rate or beats per minute (BPM).
  It is best to attach the sensor to your finger using a rubber band or other tightening
  device. Humans are generally bad at applying constant pressure to a thing. When you
  press your finger against the sensor it varies enough to cause the blood in your
  finger to flow differently which causes the sensor readings to go wonky.
  Board: Arduino Uno R3 (or R4)
  Component: Pulse Oximeter and Heart Rate Sensor(MAX30102)
  Library: https://github.com/sparkfun/SparkFun_MAX3010x_Sensor_Library  (SparkFun MAX3010x Pulse and Proximity Sensor Library)
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4;  //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE];     //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0;  //Time at which the last beat occurred
float beatsPerMinute;  //Current BPM value
int beatAvg;           //Average BPM value
  Serial.begin(9600);
  Serial.println("Initializing...");
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST))  //Use default I2C port, 400kHz speed
    Serial.println("MAX30102 was not found. Please check wiring/power. ");
    while (1) ; //Infinite loop to stop the program
  Serial.println("Place your index finger on the sensor with steady pressure.");
  particleSensor.setup();                     //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A);  //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0);   //Turn off Green LED
  long irValue = particleSensor.getIR();
  if (checkForBeat(irValue) == true) {
    //Calculate beatsPerMinute
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    //Check if the BPM value is within a valid range
    if (beatsPerMinute < 255 && beatsPerMinute > 20) {
      rates[rateSpot++] = (byte)beatsPerMinute;
      rateSpot %= RATE_SIZE;
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0; x < RATE_SIZE; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  // Print IR value, current BPM, and average BPM to Serial Monitor
  Serial.print("IR=");
  Serial.print(irValue);
  Serial.print(", BPM=");
  Serial.print(beatsPerMinute);
  Serial.print(", Avg BPM=");
  Serial.print(beatAvg);
  if (irValue < 50000) {
    Serial.print(" No finger?");
  Serial.println();
