MPU6050 Module
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, we will learn how to use the MPU6050 Module with Arduino.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
MPU6050 Module |
Common Connections:
MPU6050
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit_MPU6050 , Adafruit_Sensor and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
Uses the Adafruit_MPU6050 library to retrieve data from the MPU6050 sensor.
The process involves initializing serial communication,
verifying if the sensor is detected, configuring accelerometer and gyro ranges,
reading sensor data, and displaying acceleration, rotation, and temperature values
on the serial monitor.
Board: Arduino Uno R3 (or R4)
Component: Accelerometer & Gyroscope Sensor(MPU6050)
Library: https://github.com/adafruit/Adafruit_MPU6050 (Adafruit MPU6050 by Adafruit)
// Include the necessary libraries
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
// Create an object for the MPU6050 sensor
Adafruit_MPU6050 mpu;
// Initialize the serial communication
Serial.begin(9600);
// Check if the MPU6050 sensor is detected
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
Serial.println("MPU6050 Found!");
// set accelerometer range to +-8G
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
// set gyro range to +- 500 deg/s
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
// set filter bandwidth to 21 Hz
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
// Add a delay for stability
delay(100);
// Get new sensor events with the readings
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
// Print out the acceleration readings in m/s^2
Serial.print("Acceleration: X:");
Serial.print(a.acceleration.x);
Serial.print(", Y:");
Serial.print(a.acceleration.y);
Serial.print(", Z:");
Serial.print(a.acceleration.z);
Serial.println(" (m/s^2)");
// Print out the rotation readings in rad/s
Serial.print("Rotation: X:");
Serial.print(g.gyro.x);
Serial.print(g.gyro.y);
Serial.print(g.gyro.z);
Serial.println(" (rad/s)");
// Print out the temperature reading in degrees Celsius
Serial.print("Temperature: ");
Serial.print(temp.temperature);
Serial.println(" (degC)");
// Add a blank line for readability
Serial.println("");
// Add a delay to avoid flooding the serial monitor
delay(1000);
