Passive Buzzer
  • βœ… Be the first to get free learning resources.
  • βœ… Stay updated on new products & exclusive giveaways.
  • βœ… Share your creations and get real feedback.
  • πŸ‘‰ Need faster updates or support? Click [here] join our Facebook community
  • πŸ‘‰ Or join our WhatsApp group: Click [here]
Kit purchase
Looking for parts? Check out our all-in-one kits below β€” packed with components, beginner-friendly guides, and tons of fun.
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Γ—
Course Introduction
In this lesson, we will learn how to use the Passive Buzzer Module with Arduino.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
../_images/08_Passive_Module_bb.png
Common Connections:
  • Passive Buzzer Module
    • I/O: Connect to 8 on the Arduino.
    • -: Connect to GND on the Arduino.
    • +: Connect to 5V on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
  This example demonstrates how to play simple melodies
  using a passive buzzer module and the tone() function.
  Board: Arduino Uno R3 / Uno R4
  Component: Passive Buzzer Module (e.g. KY-006)
  Pin connection:
    - Buzzer signal pin -> Digital pin 8
    - VCC -> 5V
    - GND -> GND
  Note:
  Two melodies are included in this sketch.
  Only ONE melody should be active at a time.
  The other melody is commented out and can be enabled if needed.
#include "pitches.h"
const int buzzerPin = 8;
// Melody selection
// Uncomment ONE melody block below to play the desired song
// Melody 1: Ode to Joy (Beethoven) - one section
int melody[] = {
  NOTE_E4, NOTE_E4, NOTE_F4, NOTE_G4,
  NOTE_G4, NOTE_F4, NOTE_E4, NOTE_D4,
  NOTE_C4, NOTE_C4, NOTE_D4, NOTE_E4,
  NOTE_E4, NOTE_D4, NOTE_D4
int noteDurations[] = {
  4, 4, 4, 4,
  4, 4, 4, 4,
  4, 4, 4, 4,
  2, 4, 2
// Melody 2: Happy Birthday (classic version)
int melody[] = {
  NOTE_G4, NOTE_G4, NOTE_A4, NOTE_G4, NOTE_C5, NOTE_B4,
  NOTE_G4, NOTE_G4, NOTE_A4, NOTE_G4, NOTE_D5, NOTE_C5,
  NOTE_G4, NOTE_G4, NOTE_G5, NOTE_E5, NOTE_C5, NOTE_B4, NOTE_A4,
  NOTE_F5, NOTE_F5, NOTE_E5, NOTE_C5, NOTE_D5, NOTE_C5
  4, 4, 4, 4, 4, 4,
  4, 4, 4, 4, 4, 4,
  4, 4, 4, 4, 4, 4, 4,
  4, 4, 4, 4, 4, 4
  // Calculate the total number of notes in the melody
  int notes = sizeof(melody) / sizeof(melody[0]);
  // Play the melody once
  for (int i = 0; i < notes; i++) {
    // Calculate note duration
    // 1000 ms = one whole note
    // 4 = quarter note, 8 = eighth note, etc.
    int noteDuration = 1000 / noteDurations[i];
    // Generate the sound at the given frequency
    // Duration is controlled manually using delay()
    tone(buzzerPin, melody[i]);
    // Keep the note playing for the calculated duration
    delay(noteDuration);
    // Stop the sound before the next note
    noTone(buzzerPin);
    // Short pause between notes for better clarity
    delay(noteDuration * 0.3);
  // The melody is played once in setup().
  // No repetition is needed in loop().
