👉 Ready to explore and create with us? Click [Aquí] and join today!
2.2.2 Thermistor(MCP3008)
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/list2_2.2.2_thermistor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
Placa de Extensión GPIO
COMPRAR
Protoboard
COMPRAR
Cables de Puente
COMPRAR
Resistor
COMPRAR
Termistor
COMPRAR
MCP3008
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
../_images/schematic_2.2.2_thermistor_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.2_Thermistor_bb.png
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node thermistor-2.js
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
const mcpadc = require('mcp-spi-adc');
// Open MCP3008 channel 0 (CH0), analog input from thermistor voltage divider
const adc = mcpadc.openMcp3008(0, { speedHz: 1350000 }, (err) => {
  if (err) {
    console.error('Failed to open MCP3008 channel:', err);
    process.exit(1);
  console.log('MCP3008 thermistor channel opened.');
  setInterval(() => {
    adc.read((err, reading) => {
      if (err) {
        console.error('ADC read error:', err);
        return;
      const adcValue = reading.value; // Float: 0.0–1.0
      const raw = Math.round(adcValue * 1023); // 10-bit integer value
      const Vr = 3.3 * raw / 1023; // Convert to voltage (assuming 3.3V Vref)
      const R0 = 10000;            // Fixed resistor: 10k
      const B = 3950;              // B constant
      const Rt = R0 * Vr / (3.3 - Vr); // Thermistor resistance
      const tempK = 1 / ((Math.log(Rt / R0) / B) + (1 / (273.15 + 25))); // Kelvin
      const tempC = tempK - 273.15; // Celsius
      const tempF = tempC * 1.8 + 32; // Fahrenheit
      console.log(`Celsius: ${tempC.toFixed(2)} °C  |  Fahrenheit: ${tempF.toFixed(2)} °F`);
  }, 1000);
Code Explanation
setInterval(() => {
}, 1000);
Sets up a loop to read from MCP3008 channel 0 every 1000 milliseconds (1 second). The read function returns an analog value between 0.0 and 1.0.
const raw = Math.round(reading.value * 1023);
Converts the normalized float ADC value into a raw 10-bit integer (range 0–1023).
Calculates the voltage at the thermistor (Vr) using the ADC reading. Assumes MCP3008 reference voltage is 3.3V.
Uses the voltage divider formula to calculate the thermistor resistance Rt, where R0 is a fixed resistor (10kΩ) in series.
This applies the B-parameter equation (a simplified form of the Steinhart-Hart equation) to estimate the temperature in Kelvin.
These convert the Kelvin temperature to Celsius and then Fahrenheit.
Prints both the Celsius and Fahrenheit temperature values with two decimal points of precision to the console.
