Video 60: Improved Pan/Tilt Tracking Control Algorithm¶
In this tutorial, we delve into optimizing a Raspberry Pi camera control system, focusing on enhancing its speed and stability through algorithm adjustments.
Introduction: The video introduces the optimization of a Raspberry Pi camera control system to improve its speed and stability.
System Shortcomings: The previous control system was slow and made corrections one degree at a time, leading to inefficiency.
Proposed Solution: The speaker proposes adjusting the control algorithm to take “smart steps” proportional to the error, ensuring faster and more accurate movements.
Algorithm Derivation: Mathematical derivation of the new control algorithm for both pan and tilt movements is explained.
Code Implementation: The implementation of the new control algorithm is demonstrated, including adjustments to limit servo movements and ensure stability.
Testing and Conclusion: The video concludes with testing of the optimized control system, highlighting parameter adjustments for optimal performance.
Video
