1.3.1 Motor
In this project, we will learn to how to use L293D to drive a DC motor and make it rotate clockwise and counterclockwise. Since the DC Motor needs a larger current, for safety purpose, here we use the Power Supply Module to supply motors.
../_images/1.3.1_motor_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Power Supply Module
L293D
DC Motor
Schematic Diagram
../_images/1.3.1_motor_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/1.3.1_motor_circuit.png
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
../_images/1.3.1_motor_battery.jpeg
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 1.3.1_Motor_zero.py
As the code runs, the motor first rotates clockwise for 5s then stops for 5s, after that, it rotates anticlockwise for 5s; subsequently, the motor stops for 5s. This series of actions will be executed repeatedly.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import Motor
from time import sleep
# Initialize the Motor with GPIO Zero, specifying GPIO pins for forward (17), backward (27), and enable (22) control
motor = Motor(forward=17, backward=27, enable=22)
    # Main function to control the motor's direction and movement.
    # Alternates motor rotation between clockwise and counterclockwise with stops in between.
    actions = {'CW': motor.forward, 'CCW': motor.backward, 'STOP': motor.stop}  # Define motor actions for readability
        # Loop through the defined actions to control motor direction
        for action in ['CW', 'STOP', 'CCW', 'STOP']:
            actions[action]()  # Execute the current action (forward, stop, backward, stop)
            print(f"{action}")  # Display the current action in the console
            sleep(5)  # Pause for 5 seconds before proceeding to the next action
    # Gracefully handle a keyboard interrupt (e.g., Ctrl+C) to stop the program
Code Explanation
  1. These import statements bring in the Motor class from the gpiozero library and the sleep function from the time module.
  2. This line initializes a Motor object, specifying the GPIO pins for forward (17), backward (27), and enable (22) control.
  3. The actions for motor control are defined in a dictionary for readability. An infinite loop (while True) iterates through these actions, executing each for 5 seconds.
  4. This segment allows the program to be terminated safely using a keyboard interrupt (Ctrl+C) without causing errors.
