12. Controlled by the APP
The SunFounder controller is used to control Raspberry Pi/Pico based robots.
The APP integrates Button, Switch, Joystick, D-pad, Slider and Throttle Slider widgets; Digital Display, Ultrasonic Radar, Grayscale Detection and Speedometer input widgets.
There are 17 areas A-Q , where you can place different widgets to customize your own controller.
In addition, this application provides a live video streaming service.
Let’s customize a PiCar-X controller using this app.
How to do?
  1. Install the sunfounder-controller module.
    The robot-hat, vilib, and picar-x modules need to be installed first, for details see: Install All the Modules (Important).
    cd ~
    git clone https://github.com/sunfounder/sunfounder-controller.git
    cd ~/sunfounder-controller
    sudo python3 setup.py install
  2. Run the code.
    cd ~/picar-x/example
    sudo python3 12.app_control.py
  3. Install SunFounder Controller from APP Store(iOS) or Google Play(Android).
  4. Open and create a new controller.
    Create a new controller by clicking on the + sign in the SunFounder Controller APP.
    ../_images/app1.PNG
    There are preset controllers for some products in the Preset section, which you can use as needed. Here, we select PiCar-X.
    ../_images/app_control_preset.jpg
  5. Connect to PiCar-x.
    When you click the Connect button, it will automatically search for robots nearby. Its name is defined in picarx_control.py and it must be running at all times.
    ../_images/app9.PNG
    Once you click on the product name, the message “Connected Successfully” will appear and the product name will appear in the upper right corner.
    ../_images/app10.PNG
    • You need to make sure that your mobile device is connected to the same LAN as PiCar-X.
    • If it doesn’t search automatically, you can also manually enter the IP to connect.
    ../_images/app11.PNG
  6. Run this controller.
    Click the Run button to start the controller, you will see the footage of the car shooting, and now you can control your PiCar-X with these widgets.
    ../_images/app12.PNG
    Here are the functions of the widgets.
    • A: Show the current speed of the car.
    • E: turn on the obstacle avoidance function.
    • I: turn on the line following function.
    • J: voice recognition, press and hold this widget to start speaking, and it will show the recognized voice when you release it. We have set forward, backard, left and right 4 commands in the code to control the car.
    • K: Control forward, backward, left, and right motions of the car.
    • Q: turn the head(Camera) up, down, left and right.
    • N: Turn on the color recognition function.
    • O: Turn on the face recognition function.
    • P: Turn on the object recognition function, it can recognize nearly 90 kinds of objects, for the list of models, please refer to: https://github.com/sunfounder/vilib/blob/master/workspace/coco_labels.txt.
