6. Line Tracking
This project will use the Grayscale module to make the PiCar-X move forward along a line. Use dark-colored tape to make a line as straight as possible, and not too curved. Some experimenting might be needed if the PiCar-X is derailed.
Run the Code
cd ~/picar-x/example
sudo python3 6.line_tracking.py
After running the code, PiCar-X will move forward along a line.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-x/example. After modifying the code, you can run it directly to see the effect.
from picarx import Picarx
from time import sleep
px = Picarx()
# px = Picarx(grayscale_pins=['A0', 'A1', 'A2'])
# Please run ./calibration/grayscale_calibration.py to Auto calibrate grayscale values
# or manual modify reference value by follow code
# px.set_line_reference([1400, 1400, 1400])
current_state = None
px_power = 10
offset = 20
last_state = "stop"
def outHandle():
    global last_state, current_state
    if last_state == 'left':
        px.set_dir_servo_angle(-30)
        px.backward(10)
    elif last_state == 'right':
        px.set_dir_servo_angle(30)
        px.backward(10)
        gm_val_list = px.get_grayscale_data()
        gm_state = get_status(gm_val_list)
        print("outHandle gm_val_list: %s, %s"%(gm_val_list, gm_state))
        currentSta = gm_state
        if currentSta != last_state:
            break
    sleep(0.001)
def get_status(val_list):
    _state = px.get_line_status(val_list)  # [bool, bool, bool], 0 means line, 1 means background
    if _state == [0, 0, 0]:
        return 'stop'
    elif _state[1] == 1:
        return 'forward'
    elif _state[0] == 1:
        return 'right'
    elif _state[2] == 1:
        return 'left'
if __name__=='__main__':
            print("gm_val_list: %s, %s"%(gm_val_list, gm_state))
            if gm_state != "stop":
                last_state = gm_state
            if gm_state == 'forward':
                px.set_dir_servo_angle(0)
                px.forward(px_power)
            elif gm_state == 'left':
                px.set_dir_servo_angle(offset)
            elif gm_state == 'right':
                px.set_dir_servo_angle(-offset)
                outHandle()
        print("\nKeyboardInterrupt: stop and exit")
    finally:
        px.stop()
        print("stop and exit")
        sleep(0.1)
How it works?
This Python script controls a Picarx robot car using grayscale sensors for navigation. Here’s a breakdown of its main components:
  • Import and Initialization:
    The script imports the Picarx class for controlling the robot car and the sleep function from the time module for adding delays.
    An instance of Picarx is created, and there’s a commented line showing an alternative initialization with specific grayscale sensor pins.
    px = Picarx()
  • Configuration and Global Variables:
    current_state, px_power, offset, and last_state are global variables used to track and control the car’s movement. px_power sets the motor power, and offset is used for adjusting the steering angle.
    px_power = 10
    offset = 20
    last_state = "stop"
  • outHandle Function:
    This function is called when the car needs to handle an ‘out of line’ scenario.
    It adjusts the car’s direction based on last_state and checks the grayscale sensor values to determine the new state.
    def outHandle():
            px.backward(10)
            px.backward(10)
                break
        sleep(0.001)
  • get_status Function:
    It interprets the grayscale sensor data (val_list) to determine the car’s navigation state.
    The car’s state can be ‘forward’, ‘left’, ‘right’, or ‘stop’, based on which sensor detects the line.
            return 'stop'
            return 'forward'
            return 'right'
            return 'left'
  • Main Loop:
    The while True loop continuously checks the grayscale data and adjusts the car’s movement accordingly.
    Depending on the gm_state, it sets the steering angle and movement direction.
                    outHandle()
  • Safety and Cleanup:
    The try...finally block ensures the car stops when the script is interrupted or finished.
    finally:
    px.stop()
    sleep(0.1)
In summary, the script uses grayscale sensors to navigate the Picarx robot car. It continuously reads the sensor data to determine the direction and adjusts the car’s movement and steering accordingly. The outHandle function provides additional logic for situations where the car needs to adjust its path significantly.
