4. Obstacle Avoidance
In this project, PiCar-X will detect obstacles in front of it while moving forward, and when the obstacles are too close, it will change the direction of moving forward.
Run the Code
cd ~/picar-x/example
sudo python3 4.avoiding_obstacles.py
After running the code, PiCar-X will walk forward.
If it detects that the distance of the obstacle ahead is less than 20cm, it will go backward.
If there is an obstacle within 20 to 40cm, it will turn left.
If there is no obstacle in the direction after turning left or the obstacle distance is greater than 25cm, it will continue to move forward.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-x/example. After modifying the code, you can run it directly to see the effect.
from picarx import Picarx
POWER = 50
SafeDistance = 40   # > 40 safe
DangerDistance = 20 # > 20 && < 40 turn around,
                    # < 20 backward
def main():
        px = Picarx()
        # px = Picarx(ultrasonic_pins=['D2','D3']) # tring, echo
            distance = round(px.ultrasonic.read(), 2)
            print("distance: ",distance)
            if distance >= SafeDistance:
                px.set_dir_servo_angle(0)
                px.forward(POWER)
            elif distance >= DangerDistance:
                px.set_dir_servo_angle(30)
                px.forward(POWER)
                time.sleep(0.1)
                px.set_dir_servo_angle(-30)
                px.backward(POWER)
                time.sleep(0.5)
    finally:
        px.forward(0)
if __name__ == "__main__":
    main()
How it works?
  • Importing the Picarx Module and Initializing Constants:
    This section of the code imports the Picarx class from the picarx module, which is essential for controlling the Picarx robot. Constants like POWER, SafeDistance, and DangerDistance are defined, which will be used later in the script to control the robot’s movement based on distance measurements.
    POWER = 50
    # < 20 backward
  • Main Function Definition and Ultrasonic Sensor Reading:
    The main function is where the Picarx robot is controlled. An instance of Picarx is created, which activates the robot’s functionalities. The code enters an infinite loop, constantly reading the distance from the ultrasonic sensor. This distance is used to determine the robot’s movement.
    def main():
    px = Picarx()
            # [Rest of the logic]
  • Movement Logic Based on Distance:
    The robot’s movement is controlled based on the distance read from the ultrasonic sensor. If the distance is greater than SafeDistance, the robot moves forward. If the distance is between DangerDistance and SafeDistance, it slightly turns and moves forward. If the distance is less than DangerDistance, the robot reverses while turning in the opposite direction.
        px.forward(POWER)
        px.forward(POWER)
        time.sleep(0.1)
        px.backward(POWER)
        time.sleep(0.5)
  • Safety and Cleanup with the ‘finally’ Block:
    The try...finally block ensures safety by stopping the robot’s motion in case of an interruption or error. This is a crucial part for preventing uncontrollable behavior of the robot.
    # [Control logic]
    finally:
    px.forward(0)
  • Execution Entry Point:
    The standard Python entry point if __name__ == "__main__": is used to run the main function when the script is executed as a standalone program.
    if name == "main":
        main()
In summary, the script uses the Picarx module to control a robot, utilizing an ultrasonic sensor for distance measurement. The robot’s movement is adapted based on these measurements, ensuring safe operation through careful control and a safety mechanism in the finally block.
