๐Ÿ‘‰ Ready to explore and create with us? Click [here] and join today!
3. Keyboard Control๏ƒ
In this project, we will learn how to use the keyboard to remotely control the PiCar-X. You can control the PiCar-X to move forward, backward, left, and right.
Run the Code
cd ~/picar-x/example
sudo python3 3.keyboard_control.py
Press keys on keyboard to control PiCar-X!
  • w: Forward
  • a: Turn left
  • s: Backward
  • d: Turn right
  • i: Head up
  • k: Head down
  • j: Turn head left
  • l: Turn head right
  • ctrl + c: Press twice to exit the program
from picarx import Picarx
from time import sleep
import readchar
manual = '''
    w: Forward
    a: Turn left
    s: Backward
    d: Turn right
    i: Head up
    k: Head down
    j: Turn head left
    l: Turn head right
    ctrl+c: Quit
def show_info():
    print("\033[H\033[J",end='')  # clear terminal windows
    print(manual)
if __name__ == "__main__":
        pan_angle = 0
        tilt_angle = 0
        px = Picarx()
        show_info()
            key = readchar.readkey()
            key = key.lower()
            if key in('wsadikjl'):
                if 'w' == key:
                    px.set_dir_servo_angle(0)
                    px.forward(80)
                elif 's' == key:
                    px.backward(80)
                elif 'a' == key:
                    px.set_dir_servo_angle(-35)
                    px.forward(80)
                elif 'd' == key:
                    px.set_dir_servo_angle(35)
                    px.forward(80)
                elif 'i' == key:
                    tilt_angle+=5
                    if tilt_angle>35:
                        tilt_angle=35
                elif 'k' == key:
                    tilt_angle-=5
                    if tilt_angle<-35:
                        tilt_angle=-35
                elif 'l' == key:
                    pan_angle+=5
                    if pan_angle>35:
                        pan_angle=35
                elif 'j' == key:
                    pan_angle-=5
                    if pan_angle<-35:
                        pan_angle=-35
                px.set_cam_tilt_angle(tilt_angle)
                px.set_cam_pan_angle(pan_angle)
                show_info()
                sleep(0.5)
                px.forward(0)
            elif key == readchar.key.CTRL_C:
                print("\n Quit")
                break
    finally:
        px.set_cam_tilt_angle(0)
        px.set_cam_pan_angle(0)
        px.stop()
        sleep(.2)
How it works?
PiCar-X should take appropriate action based on the keyboard characters read. The lower() function converts upper case characters into lower case characters, so that the letter remains valid regardless of case.
    key = key.lower()
        if 'w' == key:
        elif 's' == key:
        elif 'a' == key:
        elif 'd' == key:
        elif 'i' == key:
        elif 'k' == key:
        elif 'l' == key:
        elif 'j' == key:
        print("\n Quit")
        break
