2. Let PiCar-X Move
This is the first project, let’s test the basic movement of Picar-X.
Run the Code
cd ~/picar-x/example
sudo python3 2.move.py
After running the code, PiCar-X will move forward, turn in an S-shape, stop and shake its head.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-x/example. After modifying the code, you can run it directly to see the effect.
from picarx import Picarx
if __name__ == "__main__":
px = Picarx()
px.forward(30)
time.sleep(0.5)
for angle in range(0,35):
px.set_dir_servo_angle(angle)
time.sleep(0.01)
for angle in range(35,-35,-1):
time.sleep(0.01)
for angle in range(-35,0):
time.sleep(0.01)
px.forward(0)
time.sleep(1)
px.set_camera_servo1_angle(angle)
time.sleep(0.01)
time.sleep(0.01)
time.sleep(0.01)
px.set_camera_servo2_angle(angle)
time.sleep(0.01)
time.sleep(0.01)
time.sleep(0.01)
finally:
px.forward(0)
How it works?
The basic functionality of PiCar-X is in the picarx module,
Can be used to control steering gear and wheels,
and will make the PiCar-X move forward, turn in an S-shape, or shake its head.
Now, the libraries to support the basic functionality of PiCar-X are imported. These lines will appear in all the examples that involve PiCar-X movement.
The following function with the for loop is then used to make PiCar-X
move forward, change directions, and move the camera’s pan/tilt.
px.forward(speed)
forward(): Orders the PiCar-X go forward at a givenspeed.set_dir_servo_angle: Turns the Steering servo to a specificangle.set_cam_pan_angle: Turns the Pan servo to a specificangle.set_cam_tilt_angle: Turns the Tilt servo to a specificangle.
