š Ready to explore and create with us? Click [here] and join today!
2.2 Display the Levelļ
In this lesson, weāll learn how to control an LED Bar Graph using the Raspberry Pi Pico 2. An LED Bar Graph consists of 10 LEDs arranged in a line, typically used to display levels such as volume, signal strength, or other measurements. Weāll light up the LEDs sequentially to create a level display effect.
What Youāll Need
Itās definitely convenient to buy a whole kit, hereās the link:
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
10(220Ī©) |
Circuit Diagram
In this project, each of the 10 LEDs in the LED Bar Graph is connected to the Raspberry Pi Pico 2. The anodes (positive terminals) of the LEDs are connected to GPIO pins GP6 through GP15. The cathodes (negative terminals) are connected through 220Ī© resistors to the GND (ground) pin.
Wiring Diagram
Writing the Code
You can open the file
2.2_display_the_level.inofromnewton-lab-kit/arduino/2.2_display_the_level.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click āUploadā.
// Define the GPIO pins connected to the LED Bar Graph
const int ledPins[] = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
// Initialize each pin as an output
for (int i = 0; i < 10; i++) {
pinMode(ledPins[i], OUTPUT);
// Turn on LEDs sequentially
digitalWrite(ledPins[i], HIGH); // Turn on LED
delay(500); // Wait 500 milliseconds
digitalWrite(ledPins[i], LOW); // Turn off LED
After uploading the code, the LEDs on the bar graph should light up one after another, creating a level display effect. Each LED turns on for half a second and then turns off before the next one lights up.
Understanding the Code
Defining the LED Pins:
Create an array
ledPinsthat holds the GPIO pin numbers connected to each LED on the bar graph.const int ledPins[] = {6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
Initializing the Pins:
In the
setup()function, we set each pin in theledPinsarray as an output.void setup() { for (int i = 0; i < 10; i++) { pinMode(ledPins[i], OUTPUT); } }
Controlling the LEDs:
In the
loop()function, we use aforloop to iterate through each LED. We turn it on, wait for 500 milliseconds, turn it off, and then wait another 500 milliseconds before moving to the next LED.void loop() { for (int i = 0; i < 10; i++) { digitalWrite(ledPins[i], HIGH); delay(500); digitalWrite(ledPins[i], LOW); delay(500); } }
Experimenting Further
Reverse the Order: Modify the code to light up the LEDs in reverse order.
Create a Bounce Effect: After reaching the last LED, make the sequence reverse back to the first LED.
void loop() { // Ascending sequence for (int i = 0; i < 10; i++) { digitalWrite(ledPins[i], HIGH); delay(200); digitalWrite(ledPins[i], LOW); } // Descending sequence for (int i = 8; i >= 0; i--) { digitalWrite(ledPins[i], HIGH); delay(200); digitalWrite(ledPins[i], LOW); } }
Adjust the Speed: Change the delay times to make the LEDs light up faster or slower.
Conclusion
In this lesson, youāve learned how to control multiple LEDs using the Raspberry Pi Pico and how to create visual effects using simple programming constructs like loops and delays. This foundational knowledge is essential for more advanced projects involving LED displays and indicators.
