3.4 Liquid Crystal Display (LCD1602)ď
In this lesson, we will learn how to use a 1602 LCD with the Raspberry Pi Pico 2 to display text. The LCD1602 is a character-based liquid crystal display that can show 16 characters on 2 lines, making it ideal for projects that need to display information like messages, sensor readings, or status updates.
Connecting an LCD directly to a microcontroller typically requires many GPIO pins, which can limit the functionality of your project. To solve this problem, we can use an LCD1602 module that has an I2C interface. The I2C protocol uses only two data lines (SDA and SCL), allowing you to control the LCD with just two GPIO pins, freeing up other pins for additional sensors or devices.
Understanding I2C on the Raspberry Pi Pico 2
The Raspberry Pi Pico 2 supports I2C communication through multiple GPIO pins, providing flexibility for your projects. It has two I2C buses, I2C0 and I2C1, and each can be mapped to several sets of pins.
Hereâs a breakdown of the I2C-capable pins on the Pico 2:
You can choose any matching pair of SDA and SCL pins for either I2C0 or I2C1. This flexibility allows you to avoid pin conflicts with other peripherals in your project.
What Youâll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Circuit Diagram
Wiring Diagram
Writing the Code
You can open the file
3.4_liquid_crystal_display.inofromnewton-lab-kit/arduino/3.4_liquid_crystal_display.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click âUploadâ.
The
LiquidCrystal I2Clibrary is used here, you can install it from the Library Manager.
#include <Wire.h>
// Set the LCD I2C address (usually 0x27 or 0x3F)
#define LCD_ADDRESS 0x27
#define LCD_COLUMNS 16
#define LCD_ROWS 2
// Initialize the library with the I2C address and dimensions
LiquidCrystal_I2C lcd(LCD_ADDRESS, LCD_COLUMNS, LCD_ROWS);
// Initialize the LCD
lcd.init();
lcd.backlight(); // Turn on the backlight
// Print messages to the LCD
lcd.setCursor(0, 0); // Column 0, Row 0
lcd.print("Hello, World!");
lcd.setCursor(0, 1); // Column 0, Row 1
lcd.print("LCD1602 with I2C");
// Nothing to do here
After uploading the code to the Raspberry Pi Pico, the LCD should display the following:
On the first line: âHello, World!â
On the second line: âLCD1602 with I2Câ
If nothing appears on the screen, try adjusting the contrast by turning the small potentiometer (knob) on the back of the LCD module until the text becomes visible.
Understanding the Code
Including Libraries:
Wire.h: Handles I2C communication.LiquidCrystal_I2C.h: Simplifies interaction with the I2C LCD.
Defining the LCD Parameters:
LCD_ADDRESS: The I2C address of the LCD module. Common addresses are 0x27 or 0x3F. If youâre unsure, you can use an I2C scanner sketch to find the address.
#define LCD_ADDRESS 0x27 #define LCD_COLUMNS 16 #define LCD_ROWS 2
Initializing the LCD:
In
setup()Function:lcd.init(); // Initializes the LCD lcd.backlight(); // Turns on the backlight
Displaying Text:
lcd.setCursor(0, 0); // Sets cursor to column 0, row 0 lcd.print("Hello, World!"); lcd.setCursor(0, 1); // Sets cursor to column 0, row 1 lcd.print("LCD1602 with I2C");
Using Serial Input to Display Text on LCD
We can enhance the program to read input from the Serial Monitor and display it on the LCD.
Modified Code:
#include <Wire.h> #include <LiquidCrystal_I2C.h> #define LCD_ADDRESS 0x27 #define LCD_COLUMNS 16 #define LCD_ROWS 2 LiquidCrystal_I2C lcd(LCD_ADDRESS, LCD_COLUMNS, LCD_ROWS); void setup() { lcd.init(); lcd.backlight(); Serial.begin(115200); lcd.setCursor(0, 0); lcd.print("Enter text:"); } void loop() { if (Serial.available() > 0) { lcd.clear(); lcd.setCursor(0, 0); lcd.print("You typed:"); String inputText = Serial.readStringUntil('\n'); lcd.setCursor(0, 1); lcd.print(inputText); } }
After uploading the code, type a message and press
Enter. The message will be displayed on the LCD.Explanation:
Reading Serial Input: Checks if data is available on the Serial port. Reads the input string until a newline character is encountered.
if (Serial.available() > 0) { String inputText = Serial.readStringUntil('\n'); // ... }
Displaying Serial Input on LCD:
lcd.clear(); lcd.setCursor(0, 0); lcd.print("You typed:"); lcd.setCursor(0, 1); lcd.print(inputText);
Troubleshooting
No Display on LCD:
Adjust the contrast potentiometer on the back of the LCD module.
Verify the wiring connections.
Make sure the correct I2C address is used. You can scan for devices on the I2C bus. If your I2C LCD1602 is connected correctly, the address will be displayed. The default address is usually 0x27, but in some cases, it could be 0x3F.
#include <Wire.h> void setup() { Wire.begin(); Serial.begin(115200); while (!Serial); // Wait for the serial connection to be established Serial.println("\nI2C Scanner"); } void loop() { byte error, address; int nDevices; Serial.println("Scanning..."); nDevices = 0; for (address = 1; address < 127; address++) { Wire.beginTransmission(address); error = Wire.endTransmission(); if (error == 0) { Serial.print("I2C device found at address 0x"); if (address < 16) { Serial.print("0"); } Serial.println(address, HEX); nDevices++; }else if (error == 4) { Serial.print("Unknown error at address 0x"); if (address < 16) { Serial.print("0"); } Serial.println(address, HEX); } } if(nDevices == 0) { Serial.println("No I2C devices found\n"); }else { Serial.println("done\n"); } delay(5000); // Wait 5 seconds before scanning again }
Incorrect Characters Displayed:
Check for loose connections.
Verify that the LCD is properly initialized.
Further Exploration
Custom Characters:
Create and display custom characters or symbols on the LCD.
Sensor Data Display:
Read data from sensors (e.g., temperature, humidity) and display the readings on the LCD.
Multiple I2C Devices:
Connect multiple I2C devices to the Pico and manage them simultaneously.
Conclusion
In this lesson, youâve learned how to use an I2C LCD1602 display with the Raspberry Pi Pico to display text. By utilizing the I2C interface, weâve minimized the number of GPIO pins required, allowing for more complex projects with additional sensors and peripherals.
