2.1 Hello, LED!ï
Welcome to your first hardware project with the Raspberry Pi Pico 2! In this lesson, weâll learn how to make an LED blink using MicroPython. This simple project is a great way to get started with physical computing and understand how to control hardware with code.
What Youâll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(220Ω) |
Circuit Diagram
By setting the GPIO pin high or low, youâre controlling the voltage output of that pin. When the pin is high, current flows through the LED (limited by the resistor), causing it to light up. When the pin is low, no current flows, and the LED turns off.
Wiring Diagram
Writing the Code
You can open the file
2.1_hello_led.inofromnewton-lab-kit/arduino/2.1_hello_led.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click âUploadâ.
const int ledPin = 15; // GPIO pin connected to the LED
pinMode(ledPin, OUTPUT); // Initialize the GPIO pin as an output
digitalWrite(ledPin, HIGH); // Turn the LED on
delay(1000); // Wait for 1 second
digitalWrite(ledPin, LOW); // Turn the LED off
After uploading the code, you should see the LED turn on for 1 second and turn off for 1 second.
Understanding the Code
Variable Declaration:
Declare a constant integer
ledPinand assign it the value 15, which corresponds to GPIO pin 15 where the LED is connected.const int ledPin = 15;
Setup Function:
The
setup()function runs once when the board is powered on or reset. Here, we initializeledPinas an output pin usingpinMode().void setup() { pinMode(ledPin, OUTPUT); }
Loop Function:
The
loop()function runs repeatedly aftersetup().Use
digitalWrite()to set the voltage ofledPin. Setting it toHIGHprovides 3.3V, turning the LED on. Setting it toLOWdrops the voltage to 0V, turning the LED off.The
delay(1000)function creates a 1-second pause between the on and off states.
void loop() { digitalWrite(ledPin, HIGH); delay(1000); digitalWrite(ledPin, LOW); delay(1000); }
Additional Tips
Understanding the Resistor: The 220Ω resistor limits the current flowing through the LED, preventing it from burning out.
Polarity Matters: Ensure the LED is connected correctly. The longer leg is the positive anode and should be connected to the resistor leading to the GPIO pin.
Experiment: Try changing the
delay(1000)values to make the LED blink faster or slower.
Conclusion
Congratulations! Youâve built your first hardware project with the Raspberry Pi Pico 2. This simple LED blinking project is a fundamental step into the world of physical computing. From here, you can explore more complex projects by adding buttons, sensors, and other components.
