LED Bar Graphο
LED Bar Graph is an LED array, which is used to connect with electronic circuit or microcontroller. Itβs easy to connect LED bar graph with the circuit like as connecting 10 individual LEDs with 10 output pins. Generally we can use the LED bar graph as a Battery level Indicator, Audio equipments, and Industrial Control panels. There are many other applications of LED bar graphs.
The following is the internal schematic diagram of LED Bar Graph. Generally speaking, the side with the label is the anode and the other side is the cathode.
Example
2.2 Display the Level (For MicroPython User)
2.2 Display the Level (For Arduino User)
