šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
6.3 Read from the MPU-6050
In this lesson, we’ll explore how to interface the MPU-6050 6-axis motion tracking sensor with the Raspberry Pi Pico 2. The MPU-6050 combines a 3-axis gyroscope and a 3-axis accelerometer, providing raw sensor data over the I2C communication protocol.
What You’ll Need
ITEMS IN THIS KIT
Newton Lab Kit
450+
Newton Lab Kit
SN
COMPONENT
QUANTITY
Raspberry Pi Pico 2
Micro USB Cable
Jumper Wires
Several
MPU6050 Module
Understanding the MPU-6050 Sensor
The MPU-6050 sensor is widely used in projects that require motion tracking and orientation detection, such as drones, robotics, and gaming devices.
  • Accelerometer: Measures acceleration forces along the X, Y, and Z axes. This includes gravitational acceleration, allowing you to determine the tilt or orientation of the sensor.
  • Gyroscope: Measures rotational velocity around the X, Y, and Z axes, providing information about how fast the sensor is spinning.
Circuit Diagram
sch_mpu6050_ar
Wiring Diagram
wiring_mpu6050_ar
Writing the Code
We’ll write a program that initializes the MPU-6050 sensor, reads acceleration and gyroscope data, and prints the values to the Serial Monitor.
  • You can open the file 6.3_6axis_motion_tracking.ino from newton-lab-kit/arduino/6.3_6axis_motion_tracking.
  • Select the Raspberry Pi Pico 2 board and the correct port, then click ā€œUploadā€.
  • The Adafruit MPU6050 library is used here, you can install it from the Library Manager.
    ../_images/lib_mpu6050.png
#include <Adafruit_MPU6050.h>
#include <Wire.h>
// Create an MPU6050 object
Adafruit_MPU6050 mpu;
void setup(void) {
  // Initialize Serial Communication
  Serial.begin(115200);
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize the MPU6050
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  // Set accelerometer range
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  Serial.print("Accelerometer range set to: ");
  switch (mpu.getAccelerometerRange()) {
    case MPU6050_RANGE_2_G:
      Serial.println("+-2G");
      break;
    case MPU6050_RANGE_4_G:
      Serial.println("+-4G");
      break;
    case MPU6050_RANGE_8_G:
      Serial.println("+-8G");
      break;
    case MPU6050_RANGE_16_G:
      Serial.println("+-16G");
      break;
  // Set gyroscope range
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  Serial.print("Gyro range set to: ");
  switch (mpu.getGyroRange()) {
    case MPU6050_RANGE_250_DEG:
      Serial.println("+-250 deg/s");
      break;
    case MPU6050_RANGE_500_DEG:
      Serial.println("+-500 deg/s");
      break;
    case MPU6050_RANGE_1000_DEG:
      Serial.println("+-1000 deg/s");
      break;
    case MPU6050_RANGE_2000_DEG:
      Serial.println("+-2000 deg/s");
      break;
  // Set filter bandwidth
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.print("Filter bandwidth set to: ");
  switch (mpu.getFilterBandwidth()) {
    case MPU6050_BAND_260_HZ:
      Serial.println("260 Hz");
      break;
    case MPU6050_BAND_184_HZ:
      Serial.println("184 Hz");
      break;
    case MPU6050_BAND_94_HZ:
      Serial.println("94 Hz");
      break;
    case MPU6050_BAND_44_HZ:
      Serial.println("44 Hz");
      break;
    case MPU6050_BAND_21_HZ:
      Serial.println("21 Hz");
      break;
    case MPU6050_BAND_10_HZ:
      Serial.println("10 Hz");
      break;
    case MPU6050_BAND_5_HZ:
      Serial.println("5 Hz");
      break;
  Serial.println("");
  delay(100);
  // Get new sensor events with the readings
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  // Print acceleration values
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  Serial.print(" m/s^2, Y: ");
  Serial.print(a.acceleration.y);
  Serial.print(" m/s^2, Z: ");
  Serial.print(a.acceleration.z);
  Serial.println(" m/s^2");
  // Print gyroscope values
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  Serial.print(" rad/s, Y: ");
  Serial.print(g.gyro.y);
  Serial.print(" rad/s, Z: ");
  Serial.print(g.gyro.z);
  Serial.println(" rad/s");
  delay(500); // Adjust delay as needed
After uploading the code, the Serial Monitor should display the acceleration and rotation values continuously.
MPU6050 Found!
Accelerometer range set to: +-8G
Gyro range set to: +-500 deg/s
Filter bandwidth set to: 21 Hz
Acceleration X: 0.00 m/s^2, Y: 0.00 m/s^2, Z: 9.81 m/s^2
Rotation X: 0.02 rad/s, Y: -0.01 rad/s, Z: 0.00 rad/s
Acceleration X: 0.10 m/s^2, Y: 0.05 m/s^2, Z: 9.76 m/s^2
Rotation X: 0.15 rad/s, Y: -0.05 rad/s, Z: 0.02 rad/s
Gently rotate or move the MPU-6050 sensor module. Observe changes in the acceleration and rotation values corresponding to the movement.
Understanding the Code
  1. Including Libraries and Defining Constants:
    • Adafruit_MPU6050.h: Includes the MPU6050 library for easier interfacing.
    • Wire.h: Includes the I2C communication library.
    • mpu: Creates an MPU6050 object to interact with the sensor.
  2. Setup Function:
    • MPU6050 Initialization:
      Attempts to initialize the MPU6050 sensor. If unsuccessful, it prints an error message and halts the program.
      if (!mpu.begin()) {
        while (1) {
          delay(10);
    • Accelerometer Range:
      Sets the accelerometer range to ±8G and prints the current range.
          break;
          break;
    • Gyroscope Range:
      Sets the gyroscope range to ±500 degrees per second and prints the current range.
          break;
          break;
    • Setting Filter Bandwidth:
      Configures the filter bandwidth to 21 Hz to reduce noise and prints the current setting.
          break;
          break;
  3. Loop Function:
    • Reading Sensor Data:
      • sensors_event_t a, g, temp;: Creates event objects to store accelerometer, gyroscope, and temperature data.
      • mpu.getEvent(&a, &g, &temp);: Retrieves the latest sensor data.
    • Printing Sensor Data:
      • Acceleration: Prints acceleration values along the X, Y, and Z axes in meters per second squared (m/s²).
      • Rotation: Prints gyroscope values (rotational velocity) around the X, Y, and Z axes in radians per second (rad/s).
Troubleshooting
  • No Readings Displayed:
    • Check all wiring connections, especially the I2C lines (SCL and SDA).
    • Ensure the MPU-6050 sensor is receiving power (VCC and GND connections).
    • Verify that the correct GPIO pins are defined in the code.
  • Incorrect Readings:
    • Ensure that the MPU-6050 sensor is properly seated in the breadboard.
    • Verify that the sensor’s range and filter settings match the desired application.
    • Check for any loose connections or shorts in the wiring.
  • Sensor Interference:
    • Avoid placing the sensor near other electronic devices that might cause interference.
    • Ensure there are no physical obstructions blocking the sensor’s movement.
Further Exploration
  • Combining with Other Sensors:
    Integrate the MPU-6050 with GPS modules, magnetometers, or other sensors to create comprehensive tracking systems.
  • Building a Motion-Based Game Controller:
    Use the MPU-6050 to detect movement and orientation, allowing for the creation of motion-controlled gaming devices.
  • Creating a Self-Balancing Robot:
    Utilize the accelerometer and gyroscope data to maintain balance and stability in robotic applications.
  • Implementing Sensor Fusion Algorithms:
    Combine accelerometer and gyroscope data to calculate orientation angles using algorithms like the Kalman filter or complementary filter.
Conclusion
In this lesson, you’ve learned how to interface the MPU-6050 6-axis motion tracking sensor with the Raspberry Pi Pico. By leveraging the Adafruit MPU6050 library, you can easily retrieve and interpret accelerometer and gyroscope data, enabling a wide range of motion and orientation-based applications. The optional LED indicator adds a simple way to provide visual feedback based on sensor readings, enhancing the interactivity of your projects.
