5.3 Creating a Time Counter with a 4-Digit 7-Segment Display
In this lesson, we’ll learn how to use a 4-digit 7-segment display with the Raspberry Pi Pico 2 to create a simple time counter. The display will count up every second, showing the elapsed time in seconds.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
4(220Ω) |
7 |
Understanding the 4-Digit 7-Segment Display
A 4-digit 7-segment display consists of four individual 7-segment displays combined into a single module. Each digit shares the same segment control lines (a to g and dp), but each digit has its own common cathode control. This configuration allows us to control which digit is active at any given time.
To display different numbers on each digit using shared segment lines, we use a technique called multiplexing. We rapidly switch between digits, updating one digit at a time, but so quickly that it appears as if all digits are displayed simultaneously due to the persistence of vision.
Circuit Diagram
Here the wiring principle is basically the same as 5.1 Using the 74HC595 Shift Register, the only difference is that Q0-Q7 are connected to the a ~ g pins of the 4-digit 7-segment display.
Then G10 ~ G13 will select which 7-segment display to work.
Wiring Diagram
Segment Connections (through 220 Ω resistors):
Q0 → Segment a
Q1 → Segment b
Q2 → Segment c
Q3 → Segment d
Q4 → Segment e
Q5 → Segment f
Q6 → Segment g
Q7 → Segment dp (decimal point)
Common Cathode Connections (Digit Select Pins):
Digit 1 (Leftmost Digit): Connect to GP10 on the Pico
Digit 2: Connect to GP11
Digit 3: Connect to GP12
Digit 4 (Rightmost Digit): Connect to GP13
Writing the Code
You can open the file
5.3_time_counter.inofromnewton-lab-kit/arduino/5.3_time_counter.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click “Upload”.
// Define the connection pins for the shift register
#define DATA_PIN 18 // DS (Serial Data Input)
#define LATCH_PIN 19 // STCP (Storage Register Clock)
#define CLOCK_PIN 20 // SHCP (Shift Register Clock)
// Define the digit control pins for the 4-digit 7-segment display
const int digitPins[4] = { 10, 11, 12, 13 }; // DIG1, DIG2, DIG3, DIG4
// Segment byte maps for numbers 0-9
const byte digitCodes[10] = {
// Pgfedcba
0b00111111, // 0
0b00000110, // 1
0b01011011, // 2
0b01001111, // 3
0b01100110, // 4
0b01101101, // 5
0b01111101, // 6
0b00000111, // 7
0b01111111, // 8
0b01101111 // 9
unsigned long previousMillis = 0; // Stores the last time the display was updated
unsigned int counter = 0; // Counter value
// Initialize the shift register pins
pinMode(DATA_PIN, OUTPUT);
pinMode(LATCH_PIN, OUTPUT);
pinMode(CLOCK_PIN, OUTPUT);
// Initialize the digit control pins
for (int i = 0; i < 4; i++) {
pinMode(digitPins[i], OUTPUT);
digitalWrite(digitPins[i], HIGH); // Turn off all digits
unsigned long currentMillis = millis();
// Update the counter every 1000 milliseconds (1 second)
if (currentMillis - previousMillis >= 1000) {
previousMillis = currentMillis;
counter++; // Increment the counter
if (counter > 9999) {
counter = 0; // Reset counter after 9999
// Display the counter value
displayNumber(counter);
void displayNumber(int num) {
// Break the number into digits
int digits[4];
digits[0] = num / 1000; // Thousands
digits[1] = (num / 100) % 10; // Hundreds
digits[2] = (num / 10) % 10; // Tens
digits[3] = num % 10; // Units
// Display each digit
digitalWrite(digitPins[i], LOW); // Activate digit
shiftOutDigit(digitCodes[digits[i]]);
delay(5); // Small delay for multiplexing
digitalWrite(digitPins[i], HIGH); // Deactivate digit
void shiftOutDigit(byte data) {
// Send data to the shift register
digitalWrite(LATCH_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, data);
digitalWrite(LATCH_PIN, HIGH);
After uploading the code, the 4-digit 7-segment display should start counting up from 0000, incrementing by 1 every second. The count should progress as follows: 0000, 0001, 0002, …, 9999, then reset to 0000.
Understanding the Code
Defining Control Pins:
DATA_PIN (DS): Receives serial data to be shifted into the 74HC595.LATCH_PIN (STCP): Controls the latching of data from the shift register to the output pins.CLOCK_PIN (SHCP): Controls the shifting of data into the shift register.
#define DATA_PIN 18 // DS (Serial Data Input) #define LATCH_PIN 19 // STCP (Storage Register Clock) #define CLOCK_PIN 20 // SHCP (Shift Register Clock)
Defining Digit Control Pins:
Each digit’s common cathode is connected to a separate GPIO pin.
Setting a digit pin LOW activates that digit, while HIGH deactivates it.
const int digitPins[4] = {10, 11, 12, 13}; // DIG1, DIG2, DIG3, DIG4
Creating Segment Byte Maps:
Each byte represents the segments that need to be lit to display numbers 0 to 9 on a common cathode 7-segment display.
The bits correspond to segments a to g and dp:
const byte digitCodes[10] = { 0b00111111, // 0 0b00000110, // 1 0b01011011, // 2 0b01001111, // 3 0b01100110, // 4 0b01101101, // 5 0b01111101, // 6 0b00000111, // 7 0b01111111, // 8 0b01101111 // 9 };
Setup Function:
Sets the
DATA_PIN,LATCH_PIN, andCLOCK_PINas outputs.Sets all digit control pins to
HIGHto deactivate all digits at startup.
void setup() { // Initialize the shift register pins pinMode(DATA_PIN, OUTPUT); pinMode(LATCH_PIN, OUTPUT); pinMode(CLOCK_PIN, OUTPUT); // Initialize the digit control pins for (int i = 0; i < 4; i++) { pinMode(digitPins[i], OUTPUT); digitalWrite(digitPins[i], HIGH); // Turn off all digits initially } }
Loop Function:
Uses the
millis()function to track elapsed time without blocking the program.Increments the
counterevery second and resets it after reaching 9999.
void loop() { unsigned long currentMillis = millis(); // Update the counter every 1000 milliseconds (1 second) if (currentMillis - previousMillis >= 1000) { previousMillis = currentMillis; counter++; // Increment the counter if (counter > 9999) { counter = 0; // Reset counter after 9999 } } // Display the counter value displayNumber(counter); }
Displaying the Number:
Breaks the
countervalue into thousands, hundreds, tens, and units.Activates each digit one by one, sends the corresponding segment data, and deactivates the digit.
The rapid cycling between digits creates the illusion that all digits are lit simultaneously.
void displayNumber(int num) { // Break the number into individual digits int digits[4]; digits[0] = num / 1000; // Thousands digits[1] = (num / 100) % 10; // Hundreds digits[2] = (num / 10) % 10; // Tens digits[3] = num % 10; // Units // Display each digit one by one for (int i = 0; i < 4; i++) { digitalWrite(digitPins[i], LOW); // Activate current digit // Shift out the segment data for the current digit shiftOutDigit(digitCodes[digits[i]]); delay(5); // Small delay for multiplexing digitalWrite(digitPins[i], HIGH); // Deactivate current digit } }
Shifting Out the Segment Data:
Sends the segment data to the 74HC595 shift register.
shiftOut()sends the data one bit at a time, starting with the most significant bit (MSBFIRST).Latches the data to the output pins by toggling the
LATCH_PIN.
void shiftOutDigit(byte data) { // Send data to the shift register digitalWrite(LATCH_PIN, LOW); shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, data); digitalWrite(LATCH_PIN, HIGH); }
Experimenting Further
Add a Reset Button:
Connect a button to the Pico to reset the counter when pressed.
Display Different Data:
Modify the code to display sensor readings, such as temperature or light levels.
Create a Stopwatch:
Implement start, stop, and reset functionality to use the display as a stopwatch.
Conclusion
This project demonstrates how to control a 4-digit 7-segment display using a shift register and multiplexing techniques. By efficiently managing timing with millis(), we create a responsive and accurate time counter without hindering the display’s performance.
