2.5 Reading Button Value
In this lesson, we’ll learn how to read input from a pushbutton using the Raspberry Pi Pico 2. So far, we’ve used the GPIO pins mainly for output, like lighting up LEDs. Now, we’ll use a GPIO pin as an input to detect when a button is pressed. This is a fundamental skill for creating interactive projects.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
1(10KΩ) |
Circuit Diagram
As long as one side of the button pin is connected to 3.3v, and the other side pin is connected to GP14, then when the button is pressed, GP14 will be high. However, when the button is not pressed, GP14 is in a suspended state and may be high or low. In order to get a stable low level when the button is not pressed, GP14 needs to be reconnected to GND through a 10K pull-down resistor.
Button Not Pressed: The GP14 pin is connected to GND through the resistor, so it reads LOW (0).
Button Pressed: The GP14 pin is connected to 3.3V through the button, so it reads HIGH (1).
Wiring Diagram
A four-pin button is shaped like an H. Its left two pins or right two pins are connected, which means that when it crosses the central gap, it connects two half rows with the same row number. (For example, in my circuit, E23 and F23 are already connected, as are E25 and F25).
Until the button is pressed, the left and right pins are independent of each other and current cannot flow from one side to the other.
Writing the Code
You can open the file
2.5_reading_button_value.inofromnewton-lab-kit/arduino/2.5_reading_button_value.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click “Upload”.
const int buttonPin = 14; // GPIO pin connected to the button
Serial.begin(115200); // Initialize Serial Monitor at 115200 baud
pinMode(buttonPin, INPUT); // Set the button pin as input
int buttonState = digitalRead(buttonPin); // Read the state of the button
if (buttonState == HIGH) {
Serial.println("You pressed the button!");
delay(100); // Small delay to avoid reading the button too frequently
After uploading the code, click on the magnifying glass icon(Serial Monitor) in the top-right corner of the Arduino IDE.
Set the baud rate to 115200 to match the
Serial.begin(115200);line in your code.Each time you press the button, “You pressed the button!” should appear in the Serial Monitor.
Understanding the Code
Initializing Serial Communication:
Starts serial communication at a baud rate of 115200. This allows us to print messages to the Serial Monitor.
Setting Up the Button Pin:
Configures
buttonPin(GP14) as an input to read the button state.pinMode(buttonPin, INPUT);
Reading the Button State:
Reads the current state of the button. It will be
HIGHwhen pressed andLOWwhen not pressed.int buttonState = digitalRead(buttonPin);
Responding to Button Press:
If the button is pressed, print a message to the Serial Monitor.
if (buttonState == HIGH) { Serial.println("You pressed the button!"); }
Alternative: Pull-Up Resistor Configuration
You can also wire the button using a pull-up resistor. In this configuration:
Button Not Pressed: GP14 reads HIGH (1) due to the pull-up resistor connected to 3.3V.
Button Pressed: GP14 is connected to GND when the button is pressed, so it reads LOW (0).
Wiring Instructions:
Connect a 10KΩ resistor from GP14 to 3.3V.
Connect one side of the button to GP14.
Connect the other side of the button to GND.
Code Modification:
Change the condition in the
ifstatement:if (buttonState == LOW) { Serial.println("You pressed the button!"); }
Using Internal Pull-Up Resistor
The Raspberry Pi Pico 2 allows you to enable internal pull-up resistor, eliminating the need for external resistor.
Using internal resistor simplifies wiring and saves space by eliminating the need for additional external resistor on the breadboard.
Button Not Pressed: GP14 reads HIGH (1) due to the internal pull-up resistor.
Remove the 10KΩ resistor.
Code Modification:
Set the button pin as input with an internal pull-up resistor.
ifstatement.
const int buttonPin = 14; // GPIO pin connected to the button void setup() { Serial.begin(115200); // Initialize Serial Monitor at 115200 baud pinMode(buttonPin, INPUT_PULLUP); // Set the button pin as input with an internal pull-up resistor } void loop() { int buttonState = digitalRead(buttonPin); // Read the state of the button if (buttonState == LOW) { Serial.println("You pressed the button!"); } delay(100); // Small delay to avoid reading the button too frequently }
Conclusion
In this lesson, you’ve learned how to read input from a pushbutton using the Raspberry Pi Pico. This fundamental skill allows you to create interactive projects where the program responds to user input.
Further Exploration
Control an LED: Modify the code to turn an LED on when the button is pressed.
Debouncing: Implement code to handle button bouncing for more reliable input.
Multiple Buttons: Try reading input from multiple buttons to perform different actions.
