2.10 Detect Human Movementď
In this lesson, weâll learn how to use a Passive Infrared (PIR) sensor with the Raspberry Pi Pico 2 to detect human movement. PIR sensors are commonly used in security systems, automatic lighting, and other applications where motion detection is required. They detect infrared radiation emitted by warm objects, such as humans or animals, in their field of view.
What Youâll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Circuit Diagram
When the PIR module detects someone passing by, GP14 will be high, otherwise it will be low.
The PIR sensor have two potentiometers:
Sensitivity Adjustment: Controls the range of detection.
Time Delay Adjustment: Controls how long the output remains HIGH after motion is detected.
For initial testing, turn both potentiometers counterclockwise to their minimum positions. This sets the sensor to its most sensitive and shortest delay settings, allowing you to observe immediate responses.
Wiring Diagram
Writing the Code
You can open the file
2.10_detect_human_movement.inofromnewton-lab-kit/arduino/2.10_detect_human_movement.Or copy this code into Arduino IDE.
Select the Raspberry Pi Pico 2 board and the correct port, then click âUploadâ.
const int pirPin = 14; // PIR sensor output pin connected to GP14
int pirState = LOW; // Current state of PIR sensor
int val = 0; // Variable to store the PIR reading
Serial.begin(115200); // Initialize Serial Monitor
pinMode(pirPin, INPUT); // Set the PIR pin as input
Serial.println("PIR Sensor Test");
delay(2000); // Allow the PIR sensor to stabilize
val = digitalRead(pirPin); // Read the PIR sensor
if (val == HIGH) {
if (pirState == LOW) {
Serial.println("Motion detected!");
pirState = HIGH;
} else {
if (pirState == HIGH) {
Serial.println("Motion ended!");
pirState = LOW;
delay(500); // Wait half a second before checking again
When the code is running and the Serial Monitor is open:
Move in front of the PIR sensor. The Serial Monitor should display âMotion detected!â
Stop moving or move out of the sensorâs range. After a short delay, the Serial Monitor should display âMotion ended!â
Understanding the Code
Reading the PIR Sensor:
Reads the current state of the PIR sensor. It will be HIGH when motion is detected and LOW when no motion is detected.
Detecting Motion:
When motion is detected, and itâs the first detection, it prints âMotion detected!â and updates pirState.
When motion ends, it prints âMotion ended!â and updates pirState.
if (val == HIGH) { if (pirState == LOW) { Serial.println("Motion detected!"); pirState = HIGH; } } else { if (pirState == HIGH) { Serial.println("Motion ended!"); pirState = LOW; } }
Practical Applications
Security Systems: Detect intruders or unauthorized movement.
Automatic Lighting: Turn lights on when motion is detected.
Energy Saving: Power down devices when no movement is detected for a period.
Troubleshooting Tips
False Triggers:
PIR sensors can be sensitive to environmental factors like temperature changes or sunlight.
Avoid pointing the sensor directly at heat sources or windows.
Sensor Not Detecting Motion:
Ensure the sensor has had time to initialize (some sensors require up to 60 seconds).
Adjust the sensitivity potentiometer.
Interference:
Keep the sensor away from electronics that may cause electromagnetic interference.
Conclusion
In this lesson, youâve learned how to use a PIR sensor with the Raspberry Pi Pico to detect human movement. Youâve set up the hardware, written code to read the sensorâs output, and tested it to respond to motion. Understanding how to adjust the PIR sensorâs settings allows you to tailor it to your specific application, whether itâs for security, automation, or interactive projects.
