πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
5.2 - Number Display
LED Segment Display can be seen everywhere in life. For example, on an air conditioner, it can be used to display temperature; on a traffic indicator, it can be used to display a timer.
The LED Segment Display is essentially a device packaged by 8 LEDs, of which 7 strip-shaped LEDs form an β€œ8” shape, and there is a slightly smaller dotted LED as a decimal point. These LEDs are marked as a, b, c, d, e, f, g, and dp. They have their own anode pins and share cathodes. Their pin locations are shown in the figure below.
img_7seg_cathode
This means that it needs to be controlled by 8 digital signals at the same time to fully work and the 74HC595 can do this.
Schematic
sch_74hc_7seg
wiring_74hc_7seg
Wiring
74HC595
LED Segment Display
Q0
a
Q1
b
Q2
c
Q3
d
Q4
e
Q5
f
Q6
g
Q7
dp
  • You can open the file 5.2_number_display.ino under the path of euler-kit/arduino/5.2_number_display.
  • Then select the Raspberry Pi Pico board and the correct port before clicking the Upload button.
When the program is running, you will be able to see the LED Segment Display display 0~9 in sequence.
How it works?
shiftOut() will make 74HC595 output 8 digital signals. It outputs the last bit of the binary number to Q0, and the output of the first bit to Q7. In other words, writing the binary number β€œ00000001” will make Q0 output high level and Q1~Q7 output low level.
Suppose that the 7-segment Display display the number β€œ1”, we need to write a high level for b, c, and write a low level for a, d, e, f, g, and dg. That is, the binary number β€œ00000110” needs to be written. For readability, we will use hexadecimal notation as β€œ0x06”.
Similarly, we can also make the LED Segment Display display other numbers in the same way. The following table shows the codes corresponding to these numbers.
Glyph Code
Numbers
Binary Code
Hex Code
0
00111111
0x3f
0x06
0x5b
0x4f
0x66
0x6d
0x7d
7
00000111
0x07
8
01111111
0x7f
9
01101111
0x6f
Write these codes into shiftOut() to make the LED Segment Display display the corresponding numbers.
