CheerLights
CheerLights is a global network of synchronized lights that can be controlled by anyone. Join the @CheerLights - Twitter LED color-changing community, which allows LEDs around the world to change colors simultaneously. Place your LEDs in a corner of your office to remind yourself that you are not alone.
In this case, we also utilize MQTT, but instead of publishing our own messages, we subscribe to the “cheerlights” topic. This allows us to receive messages sent by others to the “cheerlights” topic and use that information to change the color of our LED strip accordingly.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
WS2812 RGB 8 LEDs Strip
../_images/05_cheerlight_bb.png
Schematic
../_images/05_cheerlight_schematic.png
Install the Library
To install the library, use the Arduino Library Manager and search for “ArduinoMqttClient” and “FastLED” and install them.
ArduinoMqttClient.h: Used for MQTT communication.
FastLED.h: Used to drive the RGB LED Strip.
Important
With the release of FastLED 3.7.0, the FastLED library now officially supports the Arduino UNO R4. Therefore, you no longer need to manually install the development version. Simply update or install the FastLED library using the Arduino Library Manager.
Warning
[Outdated] Since the FastLED library has not officially released a version supporting Arduino R4 yet, you’ll need to download the latest development code of the FastLED library and overwrite the existing FastLED library files. For detailed instructions on how to do this, please refer to the Manual Installation section. (This note will be retracted when the FastLED library officially releases an update that supports the Arduino UNO R4.)
Run the Code
  • You can open the file 05_cheerlight.ino under the path of elite-explorer-kit-main\iot_project\05_cheerlight directly.
In the code, SSID and password are stored in arduino_secrets.h. Before uploading this example, you need to modify them with your own WiFi credentials.
arduino_secrets.h
#define SECRET_SSID "your_ssid"        // your network SSID (name)
#define SECRET_PASS "your_password"        // your network password (use for WPA, or use as key for WEP)
05_cheerlight.ino
  1/*
  2  The code is designed for an Arduino Uno R4 WiFi to connect to a Wi-Fi network,
  3  subscribe to an MQTT topic, and control a chain of NeoPixel LEDs based on messages
  4  received from the MQTT broker. It listens for color commands from the cheerlights
  5  topic and updates the LED colors accordingly.
  7  Board: Arduino Uno R4 WiFi
  8  Component: WS2812
  9  Library: https://github.com/arduino-libraries/ArduinoMqttClient (ArduinoMqttClient by Arduino)
 10           https://github.com/FastLED/FastLED (FastLED by Daniel Garcia)
 11
 12*/
 13
 14#include <WiFiS3.h>
 15#include <ArduinoMqttClient.h>
 16#include <FastLED.h>
 17
 18#define NUM_LEDS 8  // Number of LEDs in the chain
 19#define DATA_PIN 6  // Data pin for LED control
 20
 21#include "arduino_secrets.h"
 22///////please enter your sensitive data in the Secret tab/arduino_secrets.h
 23char ssid[] = SECRET_SSID;    // your network SSID (name)
 24char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
 25int status = WL_IDLE_STATUS;  // the WiFi radio's status
 26
 27WiFiClient wifiClient;
 28MqttClient mqttClient(wifiClient);
 29
 30const char broker[] = "mqtt.cheerlights.com";
 31int port = 1883;
 32const char topic[] = "cheerlights";
 33
 34
 35
 36CRGB leds[NUM_LEDS];  // Array to hold LED color data
 37
 38// Define the supported CheerLights colors and their RGB values
 39String colorName[] = { "red", "pink", "green", "blue", "cyan", "white", "warmwhite", "oldlace", "purple", "magenta", "yellow", "orange" };
 40
 41int colorRGB[][3] = { 255, 0, 0,      // "red"
 42                      255, 192, 203,  // "pink"
 43                      0, 255, 0,      // "green"
 44                      0, 0, 255,      // "blue"
 45                      0, 255, 255,    // "cyan"
 46                      255, 255, 255,  // "white"
 47                      255, 223, 223,  // "warmwhite"
 48                      255, 223, 223,  // "oldlace"
 49                      128, 0, 128,    // "purple"
 50                      255, 0, 255,    // "magenta"
 51                      255, 255, 0,    // "yellow"
 52                      255, 165, 0 };  // "orange"
 53
 54
 55void setup() {
 56  //Initialize serial and wait for port to open:
 57  Serial.begin(9600);
 58
 59  while (!Serial) {
 60    ;  // wait for serial port to connect. Needed for native USB port only
 61  }
 62
 63  // check for the WiFi module:
 64  if (WiFi.status() == WL_NO_MODULE) {
 65    Serial.println("Communication with WiFi module failed!");
 66    // don't continue
 67    while (true)
 68      ;
 69  }
 70
 71  String fv = WiFi.firmwareVersion();
 72  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
 73    Serial.println("Please upgrade the firmware");
 74  }
 75
 76  // attempt to connect to WiFi network:
 77  while (status != WL_CONNECTED) {
 78    Serial.print("Attempting to connect to WPA SSID: ");
 79    Serial.println(ssid);
 80    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
 81    status = WiFi.begin(ssid, pass);
 82
 83    // wait 10 seconds for connection:
 84    delay(10000);
 85  }
 86
 87  // you're connected now, so print out the data:
 88  Serial.print("You're connected to the network");
 89  printCurrentNet();
 90  printWifiData();
 91
 92  // You can provide a unique client ID, if not set the library uses Arduino-millis()
 93  // Each client must have a unique client ID
 94  // mqttClient.setId("clientId");
 95
 96  // You can provide a username and password for authentication
 97  // mqttClient.setUsernamePassword("username", "password");
 98
 99  Serial.print("Attempting to connect to the MQTT broker: ");
100  Serial.println(broker);
101
102  if (!mqttClient.connect(broker, port)) {
103    Serial.print("MQTT connection failed! Error code = ");
104    Serial.println(mqttClient.connectError());
105
106    while (1)
107      ;
108  }
109
110  Serial.println("You're connected to the MQTT broker!");
111  Serial.println();
112
113  // set the message receive callback
114  mqttClient.onMessage(onMqttMessage);
115
116  Serial.print("Subscribing to topic: ");
117  Serial.println(topic);
118  Serial.println();
119
120  // subscribe to a topic
121  mqttClient.subscribe(topic);
122
123  // topics can be unsubscribed using:
124  // mqttClient.unsubscribe(topic);
125
126  Serial.print("Waiting for messages on topic: ");
127  Serial.println(topic);
128  Serial.println();
129
130  FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);  // Initialize LEDs
131}
132
133void loop() {
134
135  // call poll() regularly to allow the library to receive MQTT messages and
136  // send MQTT keep alives which avoids being disconnected by the broker
137  mqttClient.poll();
138
139  // Add a delay to avoid constant pinging
140  delay(5000);
141}
142
143void printWifiData() {
144  // print your board's IP address:
145  IPAddress ip = WiFi.localIP();
146  Serial.print("IP Address: ");
147
148  Serial.println(ip);
149
150  // print your MAC address:
151  byte mac[6];
152  WiFi.macAddress(mac);
153  Serial.print("MAC address: ");
154  printMacAddress(mac);
155}
156
157void printCurrentNet() {
158  // print the SSID of the network you're attached to:
159  Serial.print("SSID: ");
160  Serial.println(WiFi.SSID());
161
162  // print the MAC address of the router you're attached to:
163  byte bssid[6];
164  WiFi.BSSID(bssid);
165  Serial.print("BSSID: ");
166  printMacAddress(bssid);
167
168  // print the received signal strength:
169  long rssi = WiFi.RSSI();
170  Serial.print("signal strength (RSSI):");
171  Serial.println(rssi);
172
173  // print the encryption type:
174  byte encryption = WiFi.encryptionType();
175  Serial.print("Encryption Type:");
176  Serial.println(encryption, HEX);
177  Serial.println();
178}
179
180void printMacAddress(byte mac[]) {
181  for (int i = 5; i >= 0; i--) {
182    if (mac[i] < 16) {
183      Serial.print("0");
184    }
185    Serial.print(mac[i], HEX);
186    if (i > 0) {
187      Serial.print(":");
188    }
189  }
190  Serial.println();
191}
192
193
194void onMqttMessage(int messageSize) {
195  // we received a message, print out the topic and contents
196  Serial.print("Received a message with topic '");
197  Serial.print(mqttClient.messageTopic());
198  Serial.println("'");
199  Serial.print("Message length: ");
200  Serial.print(messageSize);
201  Serial.println(" bytes:");
202
203  // Read the message contents into a String
204  String message = mqttClient.readString();
205
206  // Convert the received message and comparison strings to lowercase
207  message.toLowerCase();
208
209  // If a message is received on the topic, you will check this message.
210  // Changes the output state according to the message
211  if (String(topic) == "cheerlights") {
212    Serial.print("Changing color to ");
213    Serial.println(message);
214    setColor(message);
215  }
216}
217
218void setColor(String color) {
219  // Loop through the list of colors to find the matching color
220  for (int colorIndex = 0; colorIndex < 12; colorIndex++) {
221    if (color == colorName[colorIndex]) {
222      // Set the color of each NeoPixel on the strip
223      for (int pixel = 0; pixel < NUM_LEDS; pixel++) {
224        leds[pixel] = CRGB(colorRGB[colorIndex][0], colorRGB[colorIndex][1], colorRGB[colorIndex][2]);
225      }
226      FastLED.show();
227    }
228  }
229}
Control global @CheerLights devices
  1. Join the Discord Server and utilize the CheerLights bot to set the color. Simply type /cheerlights in any of the channels on the CheerLights Discord Server to activate the bot.
    ../_images/05_iot_cheerlights_1.png
  2. Follow the instructions provided by the bot to set the color. This will allow you to control CheerLights devices globally.
    ../_images/05_iot_cheerlights_2.png
How it works?
Here are the main parts of the code and explanations of their functions:
  1. Include the required libraries:
    • WiFiS3.h: Used for handling Wi-Fi connections.
    • ArduinoMqttClient.h: Used for handling MQTT connections.
    • FastLED.h: Used for controlling NeoPixel LED strips.
  2. Define some constants:
    • NUM_LEDS: The number of LEDs on the LED strip.
    • DATA_PIN: The data pin connected to Arduino for controlling the LED strip.
    • arduino_secrets.h: Header file containing Wi-Fi network name and password to protect sensitive information.
    • broker: Address of the MQTT server.
    • port: Port of the MQTT server.
    • topic: The MQTT topic to subscribe to.
  3. Define some global variables:
    • CRGB leds[NUM_LEDS]: An array to store LED color data.
    • colorName: An array of color names supported by the CheerLights project.
    • colorRGB: An array of RGB color codes corresponding to color names.
  4. setup() function:
    • Initialize serial communication.
    • Check if the Wi-Fi module is present and output its firmware version.
    • Attempt to connect to the Wi-Fi network; if it fails, wait 10 seconds and retry.
    • Upon successful connection, connect to the MQTT broker (server) and subscribe to the specified topic.
    • Initialize the NeoPixel LED strip.
  5. loop() function:
    • Periodically call the mqttClient.poll() function to receive MQTT messages and send MQTT keep-alive signals.
    • Add a 5-second delay to avoid continuous connection.
  6. printWifiData() and printCurrentNet() functions are used to output Wi-Fi network and connection information.
  7. printMacAddress() function is used to print the MAC address in hexadecimal format.
  8. onMqttMessage() function is a callback function triggered when an MQTT message is received. It outputs the received topic and message content, converting the message content to lowercase. If the topic is “cheerlights,” it calls the setColor() function to set the LED strip color.
  9. setColor() function takes a color name as a parameter, then looks for a matching color in the colorName array. If a matching color is found, it sets the LED strip’s color to the corresponding RGB value and updates the LED strip’s color using the FastLED.show() function.
