Simple Webserver
This simple Arduino program is designed to create a basic WiFi web server, allowing users to control the on and off state of an LED on the Arduino board via a web browser.
Run the Code
You can open the file
01_simple_webserver.inounder the path ofelite-explorer-kit-main\iot_project\01_simple_webserverdirectly.Or copy this code into Arduino IDE.
In the code, SSID and password are stored in arduino_secrets.h. Before uploading this example, you need to modify them with your own WiFi credentials.
#define SECRET_SSID "your_ssid" // your network SSID (name)
#define SECRET_PASS "your_password" // your network password (use for WPA, or use as key for WEP)
1/*
2 WiFi Web Server LED Blink
4 A simple web server that lets you blink an LED via the web.
5 This sketch will print the IP address of your WiFi module (once connected)
6 to the Serial Monitor. From there, you can open that address in a web browser
7 to turn on and off the LED_BUILTIN.
8
9 If the IP address of your board is yourAddress:
10 http://yourAddress/H turns the LED on
11 http://yourAddress/L turns it off
12
13 This example is written for a network using WPA encryption. For
14 WEP or WPA, change the WiFi.begin() call accordingly.
15
16 Circuit:
17 * Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and Uno WiFi Rev.2)
18 * LED attached to pin 9
19
20 created 25 Nov 2012
21 by Tom Igoe
22
23 Find the full UNO R4 WiFi Network documentation here:
24 https://docs.arduino.cc/tutorials/uno-r4-wifi/wifi-examples#simple-webserver
25 */
26
27#include "WiFiS3.h"
28
29#include "arduino_secrets.h"
30///////please enter your sensitive data in the Secret tab/arduino_secrets.h
31char ssid[] = SECRET_SSID; // your network SSID (name)
32char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
33int keyIndex = 0; // your network key index number (needed only for WEP)
34
35int led = LED_BUILTIN;
36int status = WL_IDLE_STATUS;
37WiFiServer server(80);
38
39void setup() {
40 Serial.begin(9600); // initialize serial communication
41 pinMode(led, OUTPUT); // set the LED pin mode
42
43 // check for the WiFi module:
44 if (WiFi.status() == WL_NO_MODULE) {
45 Serial.println("Communication with WiFi module failed!");
46 // don't continue
47 while (true);
48 }
49
50 String fv = WiFi.firmwareVersion();
51 if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
52 Serial.println("Please upgrade the firmware");
53 }
54
55 // attempt to connect to WiFi network:
56 while (status != WL_CONNECTED) {
57 Serial.print("Attempting to connect to Network named: ");
58 Serial.println(ssid); // print the network name (SSID);
59
60 // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
61 status = WiFi.begin(ssid, pass);
62 // wait 10 seconds for connection:
63 delay(10000);
64 }
65 server.begin(); // start the web server on port 80
66 printWifiStatus(); // you're connected now, so print out the status
67}
68
69
70void loop() {
71 WiFiClient client = server.available(); // listen for incoming clients
72
73 if (client) { // if you get a client,
74 Serial.println("new client"); // print a message out the serial port
75 String currentLine = ""; // make a String to hold incoming data from the client
76 while (client.connected()) { // loop while the client's connected
77 if (client.available()) { // if there's bytes to read from the client,
78 char c = client.read(); // read a byte, then
79 Serial.write(c); // print it out to the serial monitor
80 if (c == '\n') { // if the byte is a newline character
81
82 // if the current line is blank, you got two newline characters in a row.
83 // that's the end of the client HTTP request, so send a response:
84 if (currentLine.length() == 0) {
85 // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
86 // and a content-type so the client knows what's coming, then a blank line:
87 client.println("HTTP/1.1 200 OK");
88 client.println("Content-type:text/html");
89 client.println();
90
91 // the content of the HTTP response follows the header:
92 client.print("<p style=\"font-size:7vw;\">Click <a href=\"/H\">here</a> turn the LED on<br></p>");
93 client.print("<p style=\"font-size:7vw;\">Click <a href=\"/L\">here</a> turn the LED off<br></p>");
94
95 // The HTTP response ends with another blank line:
96 client.println();
97 // break out of the while loop:
98 break;
99 } else { // if you got a newline, then clear currentLine:
100 currentLine = "";
101 }
102 } else if (c != '\r') { // if you got anything else but a carriage return character,
103 currentLine += c; // add it to the end of the currentLine
104 }
105
106 // Check to see if the client request was "GET /H" or "GET /L":
107 if (currentLine.endsWith("GET /H")) {
108 digitalWrite(LED_BUILTIN, HIGH); // GET /H turns the LED on
109 }
110 if (currentLine.endsWith("GET /L")) {
111 digitalWrite(LED_BUILTIN, LOW); // GET /L turns the LED off
112 }
113 }
114
115 }
116 // close the connection:
117 client.stop();
118 Serial.println("client disconnected");
119 }
120}
121
122void printWifiStatus() {
123 // print the SSID of the network you're attached to:
124 Serial.print("SSID: ");
125 Serial.println(WiFi.SSID());
126
127 // print your board's IP address:
128 IPAddress ip = WiFi.localIP();
129 Serial.print("IP Address: ");
130 Serial.println(ip);
131
132 // print the received signal strength:
133 long rssi = WiFi.RSSI();
134 Serial.print("signal strength (RSSI):");
135 Serial.print(rssi);
136 Serial.println(" dBm");
137 // print where to go in a browser:
138 Serial.print("To see this page in action, open a browser to http://");
139 Serial.println(ip);
140}
After uploading the code, you will be able to see the IP address in the serial monitor. You can enter this IP address in your web browser to turn the onboard LED on/off.
How it works?
Here is an explanation of the code:
Header Files and Global Variables:
#include "WiFiS3.h": This includes the WiFi library for connecting and managing WiFi. This library is included with Arduino UNO R4 Core, so no additional installation is required.#include "arduino_secrets.h": This includes sensitive WiFi connection data such as SSID and password.ssid,pass,keyIndex: These are network credentials used for WiFi connection.led,status,server: These define the LED pin, WiFi status, and web server object.
setup():Begin serial communication.
Check for the presence of the WiFi module.
Check if the WiFi module’s firmware version is up-to-date.
Attempt to connect to the WiFi network.
Start the web server.
Print the WiFi status.
loop():Check for new web client connections.
If there are client connections, read their incoming HTTP requests.
Based on the requests, you can control the on/off state of the LED. For example, if the request is “GET /H,” it will turn on the LED; if it’s “GET /L,” it will turn off the LED.
Send an HTTP response to instruct the user on how to control the LED.
Disconnect the client.
printWifiStatus():Print the connected WiFi SSID.
Print the IP address of the Arduino board.
Print the received signal strength.
Explain how to view this page in a web browser.
