5.4 Interval¶
Sometimes you need to do two things at once. For example you might want
to blink an LED while reading a button press. In this case, you can’t
use delay()
, because Arduino pauses your program during the delay()
. If
the button is pressed while Arduino is paused waiting for the delay()
to
pass, your program will miss the button press.
An analogy would be warming up a pizza in your microwave, and also
waiting some important email. You put the pizza in the microwave and set
it for 10 minutes. The analogy to using delay()
would be to sit in front
of the microwave watching the timer count down from 10 minutes until the
timer reaches zero. If the important email arrives during this time you
will miss it.
What you would do in real life would be to turn on the pizza, and then check your email, and then maybe do something else (that doesn’t take too long!) and every so often you will come back to the microwave to see if the timer has reached zero, indicating that your pizza is done.
This sketch demonstrates how to tone an buzzer without using delay()
It turns the buzzer on and then makes note of the time. Then, each time
through loop()
, it checks to see if the desired interval time has passed.
If it has, it tone the buzzer and makes note of the new time.
In this way the buzzer tones continuously while the sketch execution never
lags on a single instruction.
Based on this condition, we can add the code of the button to control the LED, it will not be disturbed by the buzzer playing music.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
Open the
5.4.interval.ino
file under the path of3in1-kit\basic_project\5.4.interval
.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
After the code is uploaded successfully, the buzzer will play music; whenever you press the button, the LED will light up. The work of LED and buzzer does not interfere with each other.
How it works?
Initial a variable named previousMillis
to store previous operating time of microcontroller.
unsigned long previousMillis = 0;
Mark which note is played.
int thisNote=0;
The interval time of each note.
long interval = 1000;
In loop()
, declare currentMillis
to store the current time.
unsigned long currentMillis = millis();
When the interval between the current operating time and last updating time is larger than 1000ms, certain functions are triggered. Meanwhile, update the previousMillis to the current time for the next triggering that is to happen 1 second latter.
if (currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;// save the last time of the last tone
Play the notes in the melody one by one.
tone(buzzerPin,melody[thisNote],100);
interval=1000/noteDurations[thisNote]; // interval at which to tone
thisNote=(thisNote+1)%(sizeof(melody)/2); //iterate over the notes of the melody
The button control the LED.
// play button & led
digitalWrite(ledPin,digitalRead(buttonPin));
