3. Digital Read¶
Sensors capture real-world information, which is then communicated to the main board via pins (some digital, some analog) so that the computer can know the reality of the situation.
Therefore, the Arduino board can know the working status of digital sensors by reading the value of digital pins like buttons, IR obstacle avoidance module.
Here are the required functions.
pinMode(pin, mode)
: Configure the specific pin asINPUT
orOUTPUT
, here it needs to be set asINPUT
.- Syntax
pinMode(pin, mode)
- Parameters
pin
: the Arduino pin number to set the mode of.mode
: INPUT, OUTPUT, or INPUT_PULLUP.
digitalRead(pin)
: Read the value (level state) from the specified digital pin.- Syntax
digitalRead(pin)
- Parameters
pin
: the Arduino pin number you want to read
- Returns
HIGH or LOW
Example of Digital Read
int ledPin = 13; // LED connected to digital pin 13
int inPin = 7; // pushbutton connected to digital pin 7
int val = 0; // variable to store the read value
pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output
pinMode(inPin, INPUT); // sets the digital pin 7 as input
val = digitalRead(inPin); // read the input pin
digitalWrite(ledPin, val); // sets the LED to the button's value
Notes and Warnings
Pull Up & Pull Down.
digitalRead()
may produce random, indeterminate values if the pin is not getting a level signal. So directing the input pins to a known state can make the project more reliable. When using an input component such as a button, it is usually necessary to connect a pull-up or pull-down resistor in parallel to the digital input pin.Apart from connecting a pull-up resistor, you can also set the pin mode to
INPUT_PULLUP
in the code, for examplepinMode(pin,INPUT_PULLUP)
. In this case, the pin will access the Atmega’s built-in pull-up resistor via software, and it will have the same effect as connecting a pull-up resistor.About Pin13.
All digital pins (1-13) on the R3 board can be used as
digitalRead()
. But digital pin 13 is more difficult to use as a digital input than other digital pins. Because it connects an LED and resistor, it is soldered on most boards. If you enable its internal 20k pull-up resistor, it will hang around 1.7V instead of the expected 5V because the onboard LED and series resistor pull the voltage level low, which means it always returns LOW. If you must use pin 13 as a digital input, set itspinMode()
to INPUT and use an external pull-down resistor.Analog pins.
If the digital pins are not enough, the analog pins (A0-A5) can also be used as digital pins. It needs to be set to INPUT with
pinMode(pin,mode)
Related Components
Below are the related components, you can click in to learn how to use them.
