2. Move by Code¶
In the previous project, we have tried to control the operation of the motor by using different level signals for the input of the L9110 module.
If we modify the level signals through the program, then we can control the movement of the car in a flexible way.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Connect the wires between the L9110 module and the R3 board according to the diagram below.
L9110 Module |
R3 Board |
Motor |
A-1B |
A-1A |
B-1B(B-2A) |
9 |
B-1A |
10 |
OB(B) |
Black wire of right motor |
OA(B) |
Red wire of right motor |
OB(A) |
Black wire of left motor |
OA(A) |
Red wire of left motor |
Open the
2.move.inofile under the path of3in1-kit\car_project\2.move.Or copy this code into Arduino IDE.
After the code is uploaded, the car will move forward, backward, left and right for two seconds respectively.
How it works?
This project is essentially the same as the previous one, involving making the car move forward, backward, left, and right, as well as stopping by providing different signal levels to the input pins of the L9110 module.
Initialize the pins of L9110 module.
const int A_1B = 5; const int A_1A = 6; const int B_1B = 9; const int B_1A = 10; void setup() { pinMode(A_1B, OUTPUT); pinMode(A_1A, OUTPUT); pinMode(B_1B, OUTPUT); pinMode(B_1A, OUTPUT); }
Set the input pins to different high or low levels to control the rotation of the left and right motors, and then encapsulate them in individual functions.
void moveForward() { digitalWrite(A_1B, LOW); digitalWrite(A_1A, HIGH); digitalWrite(B_1B, HIGH); digitalWrite(B_1A, LOW); } void moveBackward() { digitalWrite(A_1B, HIGH); digitalWrite(A_1A, LOW); digitalWrite(B_1B, LOW); digitalWrite(B_1A, HIGH); } ...
Call these functions in
loop().void loop() { moveForward(); delay(2000); stopMove(); delay(500); moveBackward(); delay(2000); stopMove(); delay(500); ...
pin: the Arduino pin number.value: HIGH or LOW.
Write a HIGH or a LOW value to a digital pin. If the pin has been configured as an
OUTPUTwithpinMode(), its voltage will be set to the corresponding value: 5V (or 3.3V on 3.3V boards) for HIGH, 0V (ground) for LOW. -
pin: the Arduino pin number to set the mode of.mode: INPUT, OUTPUT, or INPUT_PULLUP.
Configures the specified pin to behave either as an input or an output.
ms: the number of milliseconds to pause. Allowed data types: unsigned long.
Pauses the program for the amount of time (in milliseconds) specified as parameter. (There are 1000 milliseconds in a second.)
