πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
10. One Touch StartΒΆ
In this project, we have integrated the previous projects - line following, following, obstacle avoidance, self-driving, etc. together. They can be switched by buttons on the remote control, so you can start the car and experience all functions at once.
../_images/car_10.png
  • Open the 10.one_touch_start.ino file under the path of 3in1-kit\car_project\10.one_touch_start.
  • The IRremote library is used here, you can install it from the Library Manager.
    ../_images/lib_irremote.png
After the code is uploaded successfully, the LED will flash rapidly 3 times for every signal received from the remote control by the IR receiver. You can press the following keys to operate the cart.
  • +: Accelerate
  • -: Decelerate
  • 1: Move to the left front
  • 2: Forward
  • 3: Move to the right.
  • 4: Turn left
  • 6: Turn right
  • 7: Backward to the left
  • 8: Backward.
  • 9: Backward to the right
  • CYCLE: Follow the line
  • U/SD: Self-driving
  • β–·β–·|: Obstacle avoidance with ultrasonic module
  • |◁◁: Obstacle avoidance with IR Obstacle module
  • EQ: Follow your hand
  • 0: Stop
