module utils
robot_hat.utils.set_volume(value)
Set volume
Parameters:
value (int) – volume(0~100)
robot_hat.utils.run_command(cmd)
Run command and return status and output
Parameters:
cmd (str) – command to run
Returns:
status, output
Return type:
tuple
robot_hat.utils.is_installed(cmd)
Check if command is installed
Parameters:
cmd (str) – command to check
Returns:
True if installed
Return type:
bool
robot_hat.utils.mapping(x, in_min, in_max, out_min, out_max)
Map value from one range to another range
Parameters:
  • x (float/int) – value to map
  • in_min (float/int) – input minimum
  • in_max (float/int) – input maximum
  • out_min (float/int) – output minimum
  • out_max (float/int) – output maximum
Returns:
mapped value
Return type:
float/int
robot_hat.utils.get_ip(ifaces=['wlan0', 'eth0'])
Get IP address
Parameters:
ifaces (list) – interfaces to check
Returns:
IP address or False if not found
Return type:
str/False
robot_hat.utils.reset_mcu()
Reset mcu on Robot Hat.
This is helpful if the mcu somehow stuck in a I2C data transfer loop, and Raspberry Pi getting IOError while Reading ADC, manipulating PWM, etc.
robot_hat.utils.get_battery_voltage()
Get battery voltage
Returns:
battery voltage(V)
Return type:
float
robot_hat.utils.enable_speaker()
Enable speaker
robot_hat.utils.disable_speaker()
Disable speaker
