class PWM
Example
# Import PWM class
from robot_hat import PWM
# Create PWM object with numeric pin numbering and default input pullup enabled
p0 = PWM(0)
# Create PWM object with named pin numbering
p1 = PWM('P1')
# Set frequency will automatically set prescaller and period
# This is easy for device like Buzzer or LED, which you care
# about the frequency and pulse width percentage.
# this usually use with pulse_width_percent function.
# Set frequency to 1000Hz
p0.freq(1000)
print(f"Frequence: {p0.freq()} Hz")
print(f"Prescaler: {p0.prescaler()}")
print(f"Period: {p0.period()}")
# Set pulse width to 50%
p0.pulse_width_percent(50)
# Or set prescaller and period, will get a frequency from:
# frequency = PWM.CLOCK / prescaler / period
# With this setup you can tune the period as you wish.
# set prescaler to 64
p1.prescaler(64)
# set period to 4096 ticks
p1.period(4096)
print(f"Frequence: {p1.freq()} Hz")
print(f"Prescaler: {p1.prescaler()}")
print(f"Period: {p1.period()}")
# Set pulse width to 2048 which is also 50%
p1.pulse_width(2048)
API
- class robot_hat.PWM(channel, address=None, *args, **kwargs)¶
Bases:
I2C
Pulse width modulation (PWM)
- REG_CHN = 32¶
Channel register prefix
- REG_PSC = 64¶
Prescaler register prefix
- REG_ARR = 68¶
Period registor prefix
- CLOCK = 72000000.0¶
Clock frequency
- __init__(channel, address=None, *args, **kwargs)¶
Initialize PWM
- Parameters
channel (int/str) – PWM channel number(0-13/P0-P13)
- freq(freq=None)¶
Set/get frequency, leave blank to get frequency
- Parameters
freq (float) – frequency(0-65535)(Hz)
- Returns
frequency
- Return type
float
- prescaler(prescaler=None)¶
Set/get prescaler, leave blank to get prescaler
- Parameters
prescaler (int) – prescaler(0-65535)
- Returns
prescaler
- Return type
int
- period(arr=None)¶
Set/get period, leave blank to get period
- Parameters
arr (int) – period(0-65535)
- Returns
period
- Return type
int
- pulse_width(pulse_width=None)¶
Set/get pulse width, leave blank to get pulse width
- Parameters
pulse_width (float) – pulse width(0-65535)
- Returns
pulse width
- Return type
float
- pulse_width_percent(pulse_width_percent=None)¶
Set/get pulse width percentage, leave blank to get pulse width percentage
- Parameters
pulse_width_percent (float) – pulse width percentage(0-100)
- Returns
- Return type
float
