module motor
class Motors
Example
Initilize
# Import Motor class
from robot_hat import Motors
# Create Motor object
motors = Motors()
Directly control a motor. Motor 1/2 is according to PCB mark
# Motor 1 clockwise at 100% speed
motors[1].speed(100)
# Motor 2 counter-clockwise at 100% speed
motors[2].speed(-100)
# Stop all motors
motors.stop()
Setup for high level control, high level control provides functions from simple forword, backward, left, right, stop to more complex like joystick control, motor directions calibration, etc.
All these setup only need to run once, and will save in a config file. Next time you load Motors class, it will load from config file.
# Setup left and right motors
motors.set_left_id(1)
motors.set_right_id(2)
# Go forward and see if both motor directions are correct
motors.forward(100)
# if you found a motor is running in the wrong direction
# Use these function to correct it
motors.set_left_reverse()
motors.set_right_reverse()
# Run forward again and see if both motor directions are correct
motors.forward(100)
Now control the robot
motors.forward(100)
time.sleep(1)
motors.backward(100)
time.sleep(1)
motors.turn_left(100)
time.sleep(1)
motors.turn_right(100)
time.sleep(1)
motors.stop()
API
class Motor
Example
from robot_hat import Motor, PWM, Pin
motor = Motor(PWM("P13"), Pin("D4"))
# Motor clockwise at 100% speed
motor.speed(100)
# Motor counter-clockwise at 100% speed
motor.speed(-100)
# If you like to reverse the motor direction
motor.set_is_reverse(True)
API
