1.1.6 LED Dot Matrix
As the name suggests, an LED dot matrix is a matrix composed of LEDs. The lighting up and dimming of the LEDs formulate different characters and patterns.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPIMOSI |
Pin 19 |
12 |
MOSI |
SPICE0 |
pin 24 |
10 |
CE0 |
SPISCLK |
Pin 23 |
14 |
SCLK |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Turn on the SPI before starting the experiment, refer to SPI Configuration for details.
Step 3: Install Luma.LED_Matrix module.
Step 4: Change directory.
cd ~/raphael-kit/python-pi5
Step 5: Runs the 1.1.6_LedMatrix.py Python script using the Python interpreter from the my_env virtual environment.
sudo ~/my_env/bin/python3 1.1.6_LedMatrix.py
After running the code, the LED Matrix will display a rectangle for two seconds, then the text ‘A’ for two seconds, and finally scroll to display the text “Hello, Nice to meet you!
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
from luma.core.interface.serial import spi, noop
from luma.core.render import canvas
from luma.core.virtual import viewport
from luma.led_matrix.device import max7219
from luma.core.legacy import text
from luma.core.legacy.font import proportional, CP437_FONT, LCD_FONT
serial = spi(port=0, device=0, gpio=noop())
device = max7219(serial, rotate=1)
virtual = viewport(device, width=200, height=400)
def displayRectangle():
with canvas(device) as draw:
draw.rectangle(device.bounding_box, outline="white", fill="black")
def displayLetter():
text(draw, (0, 0), "A", fill="white", font=proportional(CP437_FONT))
def scrollToDisplayText():
with canvas(virtual) as draw:
text(draw, (0, 0), "Hello, Nice to meet you!", fill="white", font=proportional(CP437_FONT))
for offset in range(150):
virtual.set_position((offset,0))
time.sleep(0.1)
def main():
displayRectangle()
time.sleep(2)
displayLetter()
time.sleep(2)
def destroy():
if __name__ == '__main__':
main()
destroy()
Code Explanation
Import the relevant libraries, of which luma.core is a component library that provides a Pillow-compatible canvas for Python 3, as well as other drawing primitives and text rendering features that support small displays on Raspberry Pi and other single-board computers.
You can visit https://luma-core.readthedocs.io/en/latest/intro.html to learn more.
Initialize the luma.led_matrix.device.max7219 class.
If you want to modify the display direction of the LED Matrix, you can do so by modifying the value of rotate, where 0 means no rotation, 1 means 90° clockwise rotation, 2 means 180° rotation, and 3 means 270° clockwise rotation.
Display a hollow rectangle in the edge area of the LED Matrix and modify the value of fill to white to display a solid rectangle.
An “A” is displayed on the (0, 0) coordinate of the LED Matrix, where CP437_FONT is a font suitable for 8*8 dot matrix screens.
There is no way to display a line of text in a single 8x8 LED matrix. We need to use the luma.core.virtual.viewport method so that the text can be scrolled through the virtual viewport.
time.sleep(0.1)
scrollToDisplayText() implements “Hello, Nice to meet you!” as a scrolling text on the LED Matrix.
First, we pass virtual as an argument to the canvas() function, so that we can use the virtual window as the current display window. Then the text() function displays “Hello, Nice to meet you!” on the LED Matrix.
Using the for loop function, we move the virtual window in the X direction so that we can see the “Hello, Nice to meet you!” text scrolling.
