Install the Libraries
For C User
BCM2835
This is a C library for Raspberry Pi (RPi). It provides access to GPIO and other IO functions on the Broadcom BCM 2835 chip, as used in the RaspberryPi, allowing access to the GPIO pins on the 26 pin IDE plug on the RPi board so you can control and interface with various external devices.
It provides functions for reading digital inputs and setting digital outputs, using SPI and I2C, and for accessing the system timers. Pin event detection is supported by polling (interrupts are not supported).
Works on all versions upt to and including RPI 4. Works with all versions of Debian up to and including Debian Buster 10.
Open a terminal and download the bcm2835 library to the ~ path.
cd ~
wget http://www.airspayce.com/mikem/bcm2835/bcm2835-1.69.tar.gz
Unzip the package.
tar zxvf bcm2835-1.69.tar.gz
Install the BCM2835 library with the following commands.
cd bcm2835-1.69
./configure
make
sudo make check
sudo make install
Reference: bcm2835
For Python User
Creating a Virtual Environment
When using Raspberry Pi or similar devices, it is recommended to install packages with pip in a virtual environment. It offers dependency isolation, increases system security, maintains system cleanliness, and facilitates project migration and sharing, simplifying dependency management. These benefits make virtual environments an extremely important and useful tool in Python development.
Below are the steps to create a virtual environment:
1. Create a virtual environment
Firstly, you need to ensure that your system has Python installed. Python version 3.3 and later come with the venv module to create virtual environments, eliminating the need for separate installation. If you are using Python 2 or a version before Python 3.3, you will need to install virtualenv.
For Python 3:
Python 3.3 and later versions can directly use the venv module:
python3 -m venv myenv
This will create a virtual environment named myenv in the current directory.
For Python 2:
If you are still using Python 2, you first need to install virtualenv:
pip install virtualenv
Then, create a virtual environment:
virtualenv myenv
This also creates a virtual environment named myenv in the current directory.
2. Activating the Virtual Environment
After creating the virtual environment, you need to activate it for use.
Each time you restart the Raspberry Pi, or open a new terminal, you will need to run the following command again to activate the virtual environment.
source myenv/bin/activate
Once the virtual environment is activated, you will see the environment name before the command line prompt, indicating you are working within the virtual environment.
3. Exiting the Virtual Environment
When you have completed your work and wish to exit the virtual environment, simply run:
deactivate
This will return you to the system’s global Python environment.
4. Deleting the Virtual Environment
If you no longer need a particular virtual environment, you can simply delete the directory containing the virtual environment:
rm -rf myenv
Luma.LED_Matrix
This is a Python 3 library for interfacing LED matrix displays using the MAX7219 driver (via SPI), WS2812 (NeoPixels, including Pimoroni Unicorn pHat/Hat and Unicorn Hat HD), and APA102 (DotStar) on the Raspberry Pi and other Linux-based single-board computers.
Add the user to the
spiandgpiogroups to ensure that the current user (replace “pi” with your own username) has permission to access the SPI and GPIO interfaces.sudo usermod -a -G spi,gpio pi
After executing this command, it’s recommended to restart the system or log out and log back in to apply the group membership changes.
Install the necessary dependencies: Use
aptto install build tools and related development libraries. These libraries are essential for compiling and installing certain Python packages.sudo apt update sudo apt install -y build-essential python3-dev python3-pip libfreetype6-dev libjpeg-dev libopenjp2-7 libtiff-dev
Create a virtual environment. Here,
~/my_envis the path for the virtual environment, and it can be customized.python3 -m venv ~/my_env
After creating the virtual environment, activate it for use.
Each time you restart the Raspberry Pi or open a new terminal, you will need to run the following command again to activate the virtual environment.
source ~/my_env/bin/activate
Once the virtual environment is activated, you will see the environment name before the command prompt, indicating you are working within the virtual environment.
Inside the virtual environment, upgrade
pipandsetuptoolsto ensure the latest versions of packages are installed.pip install --upgrade pip setuptools
Then, install
luma.led_matrix:pip install luma.led_matrix
After installation, you can verify that
luma.led_matrixis installed correctly by running the following command. If successful, it will display the version number ofluma.led_matrix.python3 -c "import luma.led_matrix; print(luma.led_matrix.__version__)"
When you are done working and wish to exit the virtual environment, simply run:
deactivate
Reference: Luma.LED_Matrix
