.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _1.1.6_py_pi5: 1.1.6 LED Dot Matrix ===================== Introduction -------------------- As the name suggests, an LED dot matrix is a matrix composed of LEDs. The lighting up and dimming of the LEDs formulate different characters and patterns. Required Components ------------------------------ In this project, we need the following components. .. image:: ../img/list_dot.png It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - Raphael Kit - 337 - |link_Raphael_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_gpio_board` - |link_gpio_board_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_dot_matrix` - |link_led_matrix_buy| Schematic Diagram ----------------------- ============ ======== ======== ==== T-Board Name physical wiringPi BCM SPIMOSI Pin 19 12 MOSI SPICE0 pin 24 10 CE0 SPISCLK Pin 23 14 SCLK ============ ======== ======== ==== .. image:: ../img/schematic_dot.png Experimental Procedures ---------------------------- **Step 1:** Build the circuit. .. image:: ../img/1.1.6fritzing.png **Step 2:** Turn on the SPI before starting the experiment, refer to :ref:`spi_configuration` for details. **Step 3:** Install :ref:`install_luma_led_matrix` module. **Step 4:** Change directory. .. raw:: html .. code-block:: cd ~/raphael-kit/python-pi5 **Step 5:** Runs the ``1.1.6_LedMatrix.py`` Python script using the Python interpreter from the ``my_env`` virtual environment. .. raw:: html .. code-block:: sudo ~/my_env/bin/python3 1.1.6_LedMatrix.py After running the code, the LED Matrix will display a rectangle for two seconds, then the text 'A' for two seconds, and finally scroll to display the text "Hello, Nice to meet you! **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``raphael-kit/python``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python from luma.core.interface.serial import spi, noop from luma.core.render import canvas from luma.core.virtual import viewport from luma.led_matrix.device import max7219 from luma.core.legacy import text from luma.core.legacy.font import proportional, CP437_FONT, LCD_FONT import time serial = spi(port=0, device=0, gpio=noop()) device = max7219(serial, rotate=1) virtual = viewport(device, width=200, height=400) def displayRectangle(): with canvas(device) as draw: draw.rectangle(device.bounding_box, outline="white", fill="black") def displayLetter(): with canvas(device) as draw: text(draw, (0, 0), "A", fill="white", font=proportional(CP437_FONT)) def scrollToDisplayText(): with canvas(virtual) as draw: text(draw, (0, 0), "Hello, Nice to meet you!", fill="white", font=proportional(CP437_FONT)) for offset in range(150): virtual.set_position((offset,0)) time.sleep(0.1) def main(): while True: displayRectangle() time.sleep(2) displayLetter() time.sleep(2) scrollToDisplayText() def destroy(): pass if __name__ == '__main__': try: main() except KeyboardInterrupt: destroy() **Code Explanation** .. code-block:: python from luma.core.interface.serial import spi, noop from luma.core.render import canvas from luma.core.virtual import viewport from luma.led_matrix.device import max7219 from luma.core.legacy import text from luma.core.legacy.font import proportional, CP437_FONT, LCD_FONT import time Import the relevant libraries, of which ``luma.core`` is a component library that provides a Pillow-compatible canvas for Python 3, as well as other drawing primitives and text rendering features that support small displays on Raspberry Pi and other single-board computers. You can visit `https://luma-core.readthedocs.io/en/latest/intro.html `_ to learn more. .. code-block:: python serial = spi(port=0, device=0, gpio=noop()) device = max7219(serial, rotate=1) Initialize the ``luma.led_matrix.device.max7219`` class. .. note:: If you want to modify the display direction of the LED Matrix, you can do so by modifying the value of rotate, where 0 means no rotation, 1 means 90° clockwise rotation, 2 means 180° rotation, and 3 means 270° clockwise rotation. .. code-block:: python def displayRectangle(): with canvas(device) as draw: draw.rectangle(device.bounding_box, outline="white", fill="black") Display a hollow rectangle in the edge area of the LED Matrix and modify the value of ``fill`` to ``white`` to display a solid rectangle. .. code-block:: python def displayLetter(): with canvas(device) as draw: text(draw, (0, 0), "A", fill="white", font=proportional(CP437_FONT)) An "A" is displayed on the (0, 0) coordinate of the LED Matrix, where ``CP437_FONT`` is a font suitable for 8*8 dot matrix screens. .. code-block:: python virtual = viewport(device, width=200, height=400) There is no way to display a line of text in a single 8x8 LED matrix. We need to use the ``luma.core.virtual.viewport`` method so that the text can be scrolled through the virtual viewport. .. code-block:: python def scrollToDisplayText(): with canvas(virtual) as draw: text(draw, (0, 0), "Hello, Nice to meet you!", fill="white", font=proportional(CP437_FONT)) for offset in range(150): virtual.set_position((offset,0)) time.sleep(0.1) ``scrollToDisplayText()`` implements "Hello, Nice to meet you!" as a scrolling text on the LED Matrix. First, we pass virtual as an argument to the ``canvas()`` function, so that we can use the virtual window as the current display window. Then the ``text()`` function displays "Hello, Nice to meet you!" on the LED Matrix. Using the for loop function, we move the virtual window in the X direction so that we can see the "Hello, Nice to meet you!" text scrolling. Phenomenon Picture ----------------------- .. image:: ../img/1.1.6led_dot_matrix.JPG
