πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1.2.1 Active Buzzer
Introduction
In this project, we will learn how to drive an active buzzer to beep with a PNP transistor.
Required Components
../_images/list_1.2.1.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Buzzer
Transistor
Schematic Diagram
In this experiment, an active buzzer, a PNP transistor and a 1k resistor are used between the base of the transistor and GPIO to protect the transistor. When the GPIO17 of Raspberry Pi output is supplied with low level (0V) by programming, the transistor will conduct because of current saturation and the buzzer will make sounds. But when high level is supplied to the IO of Raspberry Pi, the transistor will be cut off and the buzzer will not make sounds.
../_images/image332.png
Experimental Procedures
Step 1: Build the circuit. (The active buzzer has a white table sticker on the surface and a black back.)
../_images/image104.png
Step 2: Open the code file.
cd ~/raphael-kit/python
Step 3: Run.
sudo python3 1.2.1_ActiveBuzzer.py
The code run, the buzzer beeps.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
# Set GPIO17 as buzzer pin
BeepPin = 17
def setup():
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(BeepPin, GPIO.OUT, initial=GPIO.HIGH)
def main():
        # Buzzer on (Beep)
        print ('Buzzer On')
        GPIO.output(BeepPin, GPIO.LOW)
        time.sleep(0.1)
        # Buzzer off
        print ('Buzzer Off')
        GPIO.output(BeepPin, GPIO.HIGH)
        time.sleep(0.1)
def destroy():
    # Turn off buzzer
    # Release resource
    GPIO.cleanup()
if __name__ == '__main__':
    setup()
        main()
    # When 'Ctrl+C' is pressed, the program
    # destroy() will be  executed.
        destroy()
Code Explanation
Set the buzzer pin as low level to make the buzzer beep.
time.sleep(0.1)
Wait for 0.1 second. Change the switching frequency by changing this parameter.
Not the sound frequency. Active Buzzer cannot change sound frequency.
Close the buzzer.
Phenomenon Picture
../_images/image105.jpeg
