3.1.8 Password Lock
In this project, we will use a keypad and a LCD to make a combination lock. The LCD will display a corresponding prompt for you to type your password on the Keypad. If the password is input correctly, “Correct” will be displayed.
On the basis of this project, we can add additional electronic components, such as buzzer, LED and so on, to add different experimental phenomena for password input.
../_images/list_Password_Lock.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
I2C LCD1602
Keypad
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
SDA1
Pin 3
SCL1
Pin 5
../_images/Schematic_three_one9.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image262.png
Step 2: Change directory.
cd ~/raphael-kit/c/3.1.8/
Step 3: Compile.
gcc 3.1.8_PasswordLock.cpp -lwiringPi
Step 4: Run.
After the code runs, use the keypad to enter the correct password: 1984. If the “CORRECT” appears on LCD1602, there is no wrong with the password; otherwise, “WRONG KEY” will appear.
  • If there is an error prompt wiringPi.h: No such file or directory, please refer to Install and Check the WiringPi.
  • If you get Unable to open I2C device: No such file or directory error, you need to refer to I²C Configuration to enable I2C and check if the wiring is correct.
  • If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Code Explanation
#define ROWS  4
#define COLS  4
#define LENS  4
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
char password[LENS]={'1','9','8','4'};
Here, we define the length of the password LENS, storage matrix keyboard key value array KEYS and the array that stores the correct password.
There is a declaration of the subfunctions of the matrix keyboard code, refer to 2.1.8 Keypad of this document for more details.
void write_word(int data);
void send_command(int comm);
void send_data(int data);
void lcdInit();
void clear();
void write(int x, int y, char const data[]);
There is a declaration of the subfunctions of LCD1062 code, refer to 1.1.7 I2C LCD1602 of this document for more details.
        keyRead(pressed_keys);
                testword[keyIndex]=pressed_keys[0];
                keyIndex++;
                if(keyIndex==LENS){
                    if(check()==0){
                        clear();
                        write(3, 0, "WRONG KEY!");
                        write(0, 1, "please try again");
Read the key value and store it in the test array testword. If the number of stored key values is more than 4, the correctness of the password is automatically verified, and the verification results are displayed on the LCD interface.
int check(){
    for(int i=0;i<LENS;i++){
        if(password[i]!=testword[i])
        {return 0;}
Verify the correctness of the password. Return 1 if the password is entered correctly, and 0 if not.
Phenomenon Picture
../_images/image263.jpeg
