1.1.7 I2C LCD1602ο
Introductionο
LCD1602 is a character type liquid crystal display, which can display 32 (16*2) characters at the same time.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
SDA1 |
Pin 3 |
SCL1 |
Pin 5 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Setup I2C (see I2C Configuration. If you have set I2C, skip this step.)
Step 3: Change directory.
cd ~/raphael-kit/c/1.1.7/
Step 4: Compile.
gcc 1.1.7_Lcd1602.c -lwiringPi
Step 5: Run.
After the code runs, you can see Greetings!, From SunFounder
displaying on the LCD.
If there is an error prompt
wiringPi.h: No such file or directory
, please refer to Install and Check the WiringPi.If you get
Unable to open I2C device: No such file or directory
error, you need to refer to I2C Configuration to enable I2C and check if the wiring is correct.If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Code Explanation
void write_word(int data){β¦β¦}
void send_command(int comm){β¦β¦}
void send_data(int data){β¦β¦}
void init(){β¦β¦}
void clear(){β¦β¦}
void write(int x, int y, char data[]){β¦β¦}
These functions are used to control I2C LCD1602 open source code. They allow us to easily use I2C LCD1602.
Among these functions, init()
is used for initialization, clear()
is used to clear the screen, write()
is used to write what is displayed, and other functions support the above functions.
This function initializes the I2C system with the specified device symbol. The prototype of the function:
int wiringPiI2CSetup(int devId);
Parameters devId is the address of the I2C device, it can be found through the i2cdetect command(see Appendix) and the devId of I2C LCD1602 is generally 0x27.
void write(int x, int y, char data[]){}
In this function, data[]
is the character to be printed on the LCD, and the parameters x and y determine the printing position (line y+1, column x+1 is the starting position of the character to be printed).
Phenomenon Pictureο
