3.1.4 Smart Fan(MCP3008)
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPICE0 |
Pin 24 |
10 |
8 |
SPIMOSI |
Pin 19 |
12 |
10 |
SPIMISO |
Pin 21 |
13 |
9 |
SPISCLK |
Pin 23 |
14 |
11 |
GPIO22 |
Pin 15 |
22 |
GPIO5 |
Pin 29 |
21 |
GPIO6 |
Pin 31 |
22 |
GPIO13 |
Pin 33 |
23 |
13 |
Experimental Procedures
Step 1: Build the circuit.
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
Step 2: Get into the folder of the code.
cd ~/raphael-kit/c/3.1.4-2/
Step 3: Compile.
gcc 3.1.4_SmartFan.c -o SmartFan -lwiringPi -lm
Step 4: Run the executable file above.
./SmartFan
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#include <math.h>
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000
#define MotorPin1 21
#define MotorPin2 22
#define MotorEnable 23
#define BtnPin 3
int read_ADC(int channel)
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Single-ended mode and channel
buffer[2] = 0;
int result = ((buffer[1] & 3) << 8) | buffer[2];
return result;
int temperture()
int analogVal = read_ADC(0);
double Vr = 3.3 * analogVal / 1023.0; // Use 3.3V as Vref for MCP3008
double Rt = 10000.0 * Vr / (3.3 - Vr);
double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)));
double cel = temp - 273.15;
double Fah = cel * 1.8 + 32;
printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah);
return (int)cel;
int motor(int level)
if (level == 0) {
digitalWrite(MotorEnable, LOW);
if (level >= 4) {
level = 4;
digitalWrite(MotorEnable, HIGH);
softPwmWrite(MotorPin1, level * 25);
return level;
void setup()
if (wiringPiSetup() == -1) {
printf("wiringPi setup failed!\n");
return;
printf("SPI setup failed!\n");
return;
softPwmCreate(MotorPin1, 0, 100);
softPwmCreate(MotorPin2, 0, 100);
pinMode(MotorEnable, OUTPUT);
pinMode(BtnPin, INPUT);
int main(void)
setup();
int currentState, lastState = 0;
int level = 0;
int currentTemp, markTemp = 0;
while (1) {
currentState = digitalRead(BtnPin);
currentTemp = temperture();
if (currentTemp <= 0) continue;
if (currentState == 1 && lastState == 0) {
level = (level + 1) % 5;
markTemp = currentTemp;
delay(500);
lastState = currentState;
if (level != 0) {
if (currentTemp - markTemp <= -2) {
level = level - 1;
if (currentTemp - markTemp >= 2) {
level = level + 1;
level = motor(level);
Code Explanation
buffer[2] = 0;
return result;
This function is used to read analog input from MCP3008 on the specified channel. It sends a 3-byte SPI command and returns a 10-bit digital value between 0–1023.
int temperture()
return (int)cel;
The temperture() function reads the thermistor analog signal via MCP3008,
calculates voltage, resistance, then converts to Celsius and Fahrenheit using
the thermistor formula (Steinhart–Hart approximation).
if (level == 0) {
if (level >= 4) {
level = 4;
return level;
This motor() function controls fan speed via PWM.
Level ranges from 0–4, where 0 turns the fan off and each level increases the duty cycle by 25%.
void setup()
return;
return;
The setup() function initializes WiringPi, sets up SPI, configures PWM
and GPIO pins needed for motor control and button input.
int main(void)
setup();
int level = 0;
while (1) {
delay(500);
if (level != 0) {
level = level - 1;
level = level + 1;
The main() function contains the program loop:
Constantly checks button state and reads current temperature.
On button press, fan level increases (cycles 0–4) and saves temperature.
If temperature changes by ±2°C, it auto-adjusts fan speed accordingly.
Calls
motor(level)to update PWM output based on current level.
